17248 Discussions
14900kf crashes after using AI assist setting in XTU
nquinlan
Just upgraded my CPU and Motherboard. When trying to AI Assist OC my 14900kf it crashes when I run the XTU stress test . Can’t even go a few seconds without complete computer crash .
Processor : 14900KF
Motherboard: Asus ROG Strix Z790-E WFI gaming .
Memory: Corsair Dominator Titanium DDR5 6800
CPU cooler : Corsair H150 360mm radiator .
I have Asus multicore enhancement turned off .
When running Victoria 3 the game crashes constantly but my temps aren’t going to 100°c .
Any help would be appreciated.
Jose_Intel
Hello @nquinlan
Thank you for posting on the Intel️® communities.
We sincerely regret you are experiencing issues with your Intel® Core™ i9-14900KF Processor, we will be more than happy to assist you.
Please answer the following:
·      Was it working before?
·      Have you made any recent software change?
·      Have you tried setting up the memory frequency to the maximum supported of 5600 MT/s? (Memory Specifications)
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the report from the Intel® Processor Diagnostic Tool.
Jose B.
nquinlan
Hi Jose B, thank you for your quick response.
Originally the OC with XTU AI Assist seemed to be fine , But if I ruin the stress tests in XTU the system crashes . Even with small OC changes.
When I run it without any OC the 14900KF seems fine.
The only software changes I made was downloading Windows 11 but I did that the day I installed the CPU
I have XMP enabled and my memory is running at 6800MT/s
In have attached the files you requested .
Neil P. Quinlan.
Jose_Intel
Hello nquinlan
Thank you for your reply and the reports.
Please disable the XMP profile, and set up the memory frequency to the maximum supported by the Intel® Core™ i9-14900KF (5600 MT/s Memory Specifications). Let us know the outcome.
Jose B.
nquinlan
Hi Jose,
I disabled XMP and set the memory frequency to 5600 MT/s.
Ran AI Assist OC and ran the AVX2 stress test, the test failed the first attempt and a reattempt caused a computer crash.
I check my motherboards memory compatibility and my current memory isn't on it yet as they are very new.
Could this cause the problem ?
Neil.
Jose_Intel
Hello nquinlan
Thank you for following our recommendations.
Please follow this:
·       Make sure the BIOS is set to the default values.
·       Update Windows*. Select Start > Settings  > Windows Update.
·       Start the system in minimal configuration.  Minimal configuration: motherboard, processor, power supply unit, and one DRAM module at a time.
·       Check the power supply.
·       Check for memory issues:
o  Try different memory sticks.
o  Make sure the memory is seated well.
·       Try another motherboard if possible.
·       Try to get a fresh image of the operating system.
Jose B.
nquinlan
Hi Jose B.
I don't have a motherboard to swap out.
I tried all these steps otherwise and the AVX2 stress test either fails or crashes XTU or crashes the whole PC if any OC is applied .
I got one passing test with one DIMM installed but it failed 2 more consecutively .
I've run Prime95 and it failed and also caused XTU to crash .
Prime95 failed work #3
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected running 4K FFT size
IT appears that only the AVX2 test fails.
Neil P. Quinlan.
Jose_Intel
Hello nquinlan
Thank you for your reply.
We are sorry to hear that the issue persists. Please allow us to research about this issue internally, as soon as we have any updates we will post here.
Jose B.
Jose_Intel
Hello nquinlan
Thank you for patiently waiting.
This time we would like to recommend you process the RMA with us, after verifying that your warranty is still active here, directly contact Intel Customer Support to initiate the RMA process (you cannot do this through the forums). Here are pages where you can look up contact information, including local/country phone numbers, by geography:
U.S. and Canada: Intel Customer Support
Europe, Middle East, and Africa: Intel Customer Support EMEA
Asia-Pacific: Intel Customer Support APAC
Latin America: Intel Customer Support LAR
Please remember that altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. https://www.intel.com/content/www/us/en/gaming/extreme-memory-profile-xmp.html
We will send some information privately. Please note that this thread will no longer be monitored by Intel.
Jose B.
