I put together a system with the following specs:
i7 4790k
MSI Z97S Krait Edition ATX board (with latest available bios)
OCZ Trion 100 SSD 240GB
Cryorig H7 Cooler
G. Skill Sniper 1866MHz ram
Antec Neo 500W Power Supply
Gigabyte GTX 960 4GB GPU
I have not done any overclocking at all with this CPU, all motherboard bios options are at factory stock, I did notice with my XMP profile turned on that all cores go to 4.4Ghz, so I
am guessing that's something that the motherboard manufacturer did by default when XMP is turned on, I ran a small Prime95 26.6 FFT 10 minute tests and these are the results I came up with:
I have good case airflow, etc, but it was going into the 80s, an Aida64 FPU test would hit almost 90-99C, and a Realbench test would hit 80-85C.
I've seen several different issued with these chips, so I honestly dont know what should be normal or not, I'm using a better cooler than the stock cooler that came with the chip, everything is seated properly, and I even re-seated the cooler to make sure.
With the XMP profile off I ended up with these results after running the small FFTs in p95 26.6, Realbench was 71-75C, and Aida64 FPU was 83-88C:
Room temp during the testing was about 27C (80F) as I live in Florida, but even testing in the evening when the room temps were between 74-79F the temps were about the same
Gaming seems to range from 65-73C
Intel ETU tests range from 72-75C
The CPU that I have is from an X53 batch made in Vietnam if that makes any difference.
I've done everything I can think of off the top of my head, I've checked my airflow, added the aftermarket CPU cooler, re-seated it twice to make sure it was on good, and run all those tests, made sure my bios was up to date with the latest, etc. Seems like the highest temps come with the P95 26.6 tests, or the Aida64 tests, and the Realbench benchmark test going into the 80s with XMP on, and high 70s (72-75C) with XMP off.
So that leaves me with the question of is that normal for this chip with an aftermarket cooler, or is it possible this chip has bad paste on the IHS and should I consider finding out about an RMA?
Just curious as the last thing I want to end up with is a bad 300$ CPU that isn't working right.
Also wanted to add that I replaced the stock cooler because gaming temps were getting close to 80C and I didn't bother doing full stress tests, because within 20 seconds it was 90C and climbing so temps were high with stock cooler while I was waiting for the H7 to arrive (so I did not use it except for web browsing until I had gotten the H7).
Message was edited by: Billy Gray
連結已複製
Hello Xyele,
Thank you for joining the Intel communities.
Please check the following thread:
/docs/DOC-23517 https://communities.intel.com/docs/DOC-23517
This thread talks about CPU over heating with this Intel® processor.
Ivan
I took a look at that thread, and tried using the settings recommended, and that did not seem to bring down my temperatures any, they were still about the same as my first post with Prime95 26.6 or Aida64.
I've re-seated my CPU cooler 3 times now, so I've triple checked that, and made sure I tried all the settings recommended in the ETU to bring down the TDP and lower the voltage, was still about the same.
Running Real-bench gave me 69/69/70/63 on the cores at max. Gaming seems to run in the 60-70C range still. I've turned the Bios feature off that runs all cores at 4.4Ghz, as that would hit 77C running Real-bench. Prime95 is about the same temperatures, so I have stopped using either Aida or Prime altogether now.
Although from what I have seen others were getting those temperatures with the stock cooler after changing the thermal paste, and I'm getting those with an aftermarket cooler, so I dont know if that is just normal at this point, or if the chip doesn't have good paste between the lid and IHS.
I ran the Intel ETU program and hit about 63-67C with the MSI feature off, with it on, was hitting about 73-75C.
This is my first time owning an Intel chip after having AMDs for so long, and after seeing all the problems that I have seen, I wanted to make sure this chip is running properly and isn't running too hot and isn't a bad one. I've pretty much tried everything that I can think of or have read to get the temps down anymore at all after seeing others with air cooling running in the mid 50s to very low 60s or so under load, maybe I just got unlucky with the chip or don't have a powerful enough cooler.
One other thing I'd like to add is that with the stock cooler my bios was showing 50-55C, it's down to 40-43C with the Cryorig H7 cooler I used now, even under the stress tests between the stock cooler and the new cooler it's a temp drop of 10 to almost 20C, so that's why I am thinking something is wrong, and the extra pressure from the new cooler is forcing somewhat better contact with the IHS on the chip.
The Intel® Core i7- 4790K Processor has a thermal specification or Tcase (case temperature) of
74.04°C. This is the expected temperature for this chip under normal use. Normal use will be considered anything that a user can run that doesn't stresses out the CPU. When running stress testes or heavy applications you can see the CPU temperature bypassing the Tcase and eventually going up to 80°C/85°C but as soon the processor is released it must go back to whatever normal temperature it is in normal use. The normal temperature of a processor will vary depending on the chassis type and the rest of the hardware used.
100°C is a critical temperature and can generate processor damages. There are a few reasons that can be causing the high temperatures when running the stress test I your system:
In this case please run the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit- Intel® Processor Diagnostic Tool. The purpose of the Intel® Processor Diagnostic Tool is to verify the functionality of an Intel® microprocessor. The diagnostic checks for brand identification, verifies the processor operating frequency, tests specific processor features and performs a stress test on the processor.
Please make sure you have the latest bios version with your motherboard and let me know the results when you run the Intel® Processor Diagnostic Tool, you can post the result here.
At the top of the Window is a Menu Bar. The "File" Menu allows you to open the TestResults.txt file using Notepad, and allows you to exit IPDT.
Just to make sure it was a good test run, I double checked my bios was up to date, then I cleared my CMOS and set everything to default in the bios, and only turned
on my XMP profile for ram speed, and then ran the test.
These are the results that I got from running the test, and I'm assuming the max temperature is 100/105C? Since I was watching my temps and saw them hit 68-70 during the test.
--- Testing Processor 1 ---
--- IPDT64 - rev 2.20.0.0.W.MP ---
--- Start Time: 01/11/2016 14:29:47---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 66 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i7-4790K 4.00GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 4.00
Detected CPU Frequency is --> 4.10438
CPU Frequency Test Passed!!!
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 100
Base Clock test Pass ---
..QPI rate Test not supported..
..Skipping QPI rate Test..
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 532.8
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 5.98121e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 4 x 32
- Detected L1 Inst Cache Size --> 4 x 32
- Detected L2 Cache Size --> 1024
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
MMX SSE Testing Passed !!
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
AVX AES PCLMULQDQ Testing Passed !!
--- Reading Memory Size ---
Detected Memory Size is --> 8.00GB
--- Integrated Memory Controller Stress Test ---
--- Integrated Memory Controller Stress Test Pass!!! ---
Integrated Memory Controller Test Pass!!!
Chipset : Intel® 9 Series Chipset - Z97
Chipset Stepping : A0
2 device connected to PCI Express Port 0
1 : NVIDIA GeForce GTX 960
2 : High Definition Audio Controller
No device connected to PCI Express Port 1
1 device connected to PCI Express Port 3
1 : PCI-to-PCI Bridge
1 device connected to PCI Express Port 4
1 : Realtek PCIe GBE Family Controller
2 device connected to SATA Controller 1
1 : WDC WD5000AAJS-32YFA0
2 : OCZ-TRION100
3USB devices detected
1 : Xbox 360 Controller for Windows
2 : USB Input Device
3 : Logitech USB Camera (Webcam 500)
1 device connected to Intel High Definition Audio Controller
1 : Realtek High Definition Audio
--- Platform Controller Hub Test Completed!!! ---
..Query 2..
--- Querying for Intel(R) Integrated Graphics Device (IGD) ---
..Did not detect Intel(R) Integrated Graphics Device (IGD).
..This could be that the test platform is using a discrete graphics card.
..To test IGD, verify that there is an onboard video connector,
..shutdown the test platform, remove the graphics card, and
..move video cable from graphics card to onboard video connector
..Skipping Intel(R) Integrated Graphics Device Presence Test..
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
Temperature = 39 degrees C below maximum.
--- Test End Time: 01/11/2016 14:33:47---
System Information
Processor Name: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Processor Information: Intel64 Family 6 Model 60 Stepping 3
Number of Physical Cores: 4
Number of Logical Cores: 8
Installed System Memory: 8 GB
Operating System: Microsoft Windows 10 Pro 64-bit
Graphics Information: NVIDIA GeForce GTX 960
System Product: Z97S SLI KRAIT EDITION (MS-7922)
System BIOS: V10.6
I can see that this temperature is fine and there are no errors with the processor, I would recommend turning off the XMP (Extreme Memory Profile) mode for a while and check the temperature to see what happens.
Do you get any freezing problems, blue screen of death or any problems when you run your system?
I have not noticed any freezing or BSODs with my system, I've mainly been concerned with making sure that I do not have a chip that has poor paste under the lid, as seems to be so very
common with this chip, as over 300$ for a chip that could possibly have bad paste is very worrisome.
I ran a new diagnostic with the MSI Enhanced Turbo disabled, which I noticed was enabling itself by default with XMP profiles and running all cores a 4.4Ghz instead of the x44 x44 x43 x42 Intel Specs for the chip. These are the results of that test:
--- Start Time: 01/12/2016 17:37:09---
Temperature = 70 degrees C below maximum.
Detected CPU Frequency is --> 4.33922
Expected frequency - The highest frequency at which the tested processor was manufactured to operate
Detected frequency - The frequency at which the tested processor is currently operating
Power management modes can create marginally higher or lower detected frequency
than expected frequency. Small variations in clock frequencies are common.
Operation Per Second--> 5.31663e+006
--- MMX SSE ---
2 : OCZ-TRION100
..Query 2..
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
--- Test End Time: 01/12/2016 17:41:08---
System Information
Processor Name: Intel(R) Core(...
Hello Xyele,
I appreciate you have posted this information for us to see it.
This processor is running perfectly fine and you don't need to worry about it, that temperature is OK, please bear in mind that the K processors are hotter than the rest.
Usually when you do a stress test you will see that the temperature will go up but after the stress is done it will go back to a lower temperature.
Ivan
