is a p4 3.4processor 64bit
If i had the SL number of the CPU, i could have checked it for you.
Anyway, the SL number is found on the CPU itself - the markings are found on the metal.
http://www.intel.com/support/processors/sb/CS-030330.htm http://www.intel.com/support/processors/sb/CS-030330.htm
Get the SL number of the CPU and search it on the link below.
You can check the information from the website below:
http://ark.intel.com/ http://ark.intel.com/
If the Intel® 64 is checked, then it does support 64 bit.
All the best,
Kind Regards,
Aryan.
