17151 Discussions
667 mhz memory at 912 mhz and a core 2 duo e8400 @ 4.2ghz
is this good all on air cooling and the front side bus is at 1872mhz i have 2 his radeon 3870's incrossfire mode at 795 , and 1260.
What are the temps?
IF you're using an enclosed computer case, you could quiet the fan-noise with foam lineing, and a sound-baffle for the air inlets/outlets...
Also, if you live in a cold climate, it helps to position the CPU-case exhaust-side near your feet
