17158 Discussions
6700k High stock voltage + High temps
MProd
I recently bought a 6700k with a high performance water cooler(h110i) on an Asus Z170A board, when I got it i saw a stock voltage of 1.28V which seemed high and it was, gave high temps , i tried lowering it down to 1.22 and my pc BSODed, The high voltage doesn't bother me on stock settings but I bought the K version to overclock it and with those high voltages it seems really hard to get a stable OC on this chip, should i RMA?
Hi Mprodani,
Could you please attach the result of the Intel® Processor Diagnostic Tool?
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Also in case your processor was under the Tuning Protection Plan, https://click.intel.com/tuningplan/ https://click.intel.com/tuningplan/, if it is necessary you can contact our support center to process the replacement:
http://www.intel.com/content/www/us/en/support/contact-support.html http://www.intel.com/content/www/us/en/support/contact-support.html
Btw, I recommend you to take a look on this website for further support on Overclocking
http://hwbot.org/ http://hwbot.org/
Also, here you can find Two Intel® Tools Simplify the Overclocking Process,
http://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html http://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html
Hellen.
Hi Mprodani,
I would like to know if the information provided helps you.
Hellen.
CCris2
New Contributor II
Hi mprodani,
First of all on Asus mainboard you should set CPU voltage to Adaptive, on auto will stay all time on maximum voltage.
On Adaptive when is in idle will have about 0.7V and when under load 1,2V.
CCris2
New Contributor II
If you have high temps on stock frequency, you should check if that water cooler is working and mounted correctly.
Hi Mprodani,
I'm just following on this thread to ask you if your issue was resolved with the information provided above.
Hellen.
