16804 Discussions
.79GHz speed in i58400
Aarambh
i use i5 -8400 in asus b360m-d , but my system speed very low
its how show speed only .79GHz
how to fix it
system base speed (2.91GHz)
Jose_Intel
Hello @Aarambh
Thank you for posting on the Intel️® communities.
We understand your concern about the base frequency of your Intel® Core™ i5-8400 Processor, we will be more than happy to give you some information.
Please keep in mind that the performance is managed by the operating system, depending on the workload. The processor won’t be always at the base frequency or Max Turbo Frequency.
Our recommendation is to have your system up to date. Please go to select Start > Settings > Windows Update.
Another recommendation is to update the BIOS (for further assistance, please contact the system manufacturer).
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
DeividA_Intel
Hello Aarambh,
I am following up because I want to know if your issue with a low frequency persists. Let me know if you need further support.
Deivid A.
DeividA_Intel
Hello Aarambh,
I was checking your thread and noticed that I have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
