- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have been exchanging emails with Asus over the past few weeks, trying to get VT-d working in Xen on a P6T (X58) series board with an i7-920.
Does Intel have any say in how their technology is implemented by a company like ASUS (if it is not being implemented properly?) because ASUS is showing no effort to fix this. There is supposedly a beta BIOS that has working VT-d, but it was never released to public (http://wiki.xensource.com/xenwiki/VTdHowTo http://wiki.xensource.com/xenwiki/VTdHowTo). The problem has been reported to Asus, for years now, that VT-d is not working in Xen nor ESXi on this board, but they are leaving the VT-d option in all BIOS updates and it still doesn't work when it is turned on!
Please help me out here, if it is at all possible. Also note that a VT-x setting in the BIOS is available, and is a separate option from the VT-d setting.
Here is a transcript of my communication with ASUS so far, with all sensitive information stripped:
> ---------- Original Message ----------
> Sent : 2012-3-6 20:59:52
> Subject : Motherboard P6T Deluxe V2
> Apply date : 3/6/2012 9:01:33 PM(UTC Time)
> [Product Information]
> *Product Type : Motherboard
> *Product Model : P6T Deluxe V2
> *Date of Purchase : 2009/11/1
> [Motherboard Specification]
> *Motherboard BIOS Revision : 1202
> [VGA Card Specification]
> *VGA Card Vendor : ASUS
> *VGA Card Model : EN210
> *VGA Card Chipset : GeForce 210
> *VGA Card Driver : nVidia 295.20
> [CPU Specification]
> *CPU Vendor : Intel
> *CPU Type : i7 Socket 1366
> *CPU Speed : 2.67GHz
> [Memory Specification]
> *Memory Vendor : Kingston
> *Memory Model : PVT36G1333ELK
> *Memory Capacity : 6GB
> [HDD Specification]
> HDD Vendor : Intel
> HDD Model : Series 320
> HDD Capacity : 120GB
> *Operating System : Linux
> [Problem Description]
> Please provide me a BIOS for P6T Deluxe V2 that implements ACPI Direct
> Memory
> Access remapping (DMAR) tables correctly for Intel VT-d usage, or notify
> me if ASUS
> believes that the current 1202 BIOS conforms to Intel VT-d specifications.
> With VT-d enabled in BIOS the P6T Deluxe V2 (BIOS 1202, 2011/10/10)
reports
> RMRR (Reserved Memory Region Reporting Structure) is bf7dc000 - bf7dbfff
> e820 table:
> 0000000000000000 - 000000000009e400 (usable)
> 000000000009e400 - 00000000000a0000 (reserved)
> 00000000000e4c00 - 0000000000100000 (reserved)
> 0000000000100000 - 00000000bf780000 (usable)
> 00000000bf780000 - 00000000bf798000 (ACPI data)
> 00000000bf798000 - 00000000bf7dc000 (ACPI NVS)
> 00000000bf7dc000 - 00000000c0000000 (reserved)
> 00000000fee00000 - 00000000fee01000 (reserved)
> 00000000ffe00000 - 0000000100000000 (reserved)
> 0000000100000000 - 00000001c0000000 (usable)
> but Xen system log has:
> (XEN) [VT-D]dmar.c:528: RMRR address range not in reserved memory base >
bf7dc000 end = bf7dbfff; iommu_inclusive_mapping=1 parameter may be needed.
> (XEN) [VT-D]dmar.c:585: The RMRR (bf7dc000, bf7dbfff) is incorrect!
> (XEN) Failed to parse ACPI DMAR. Disabling VT-d.
> iommu_inclusive_mapping parameter does not resolve the issue.
> Thank you
On 15/03/12 04:30 AM, Andrew wrote:
> Dear Valued Customer,
> Thank you for contacting ASUS Customer Service.
> My name is Andrew and it's my pleasure to help you with your problem.
> Sorry for my delay. > This board can only support VT-X ,so you will need check it in the manual.
> Welcome to refer Troubleshooting & FAQ for ASUS products in ASUS website:
> http://support.asus.com/servicehome.aspx?SLanguage=en http://support.asus.com/servicehome.aspx?SLanguage=en
> If you continue to experience issues in the future, please do not
> hesitate to contact us.
> Best Regards,
> Andrew
Sent : 2012-3-15 16:49:01
Subject : Re: Motherboard P6T Deluxe V2
Hi Andrew,
On P6T Deluxe V2:
Page 3-28 of manual under section "3.5.2 Chipset" states Intel VT-d
configuration 'Allows you to enable or disable the Intel Virtualization
Technology for Directed I/O'
This is the feature I would like to use, and it is included in the
manual for this board and the option for the feature is present in the BIOS.
Please review my request for a BIOS that implements the feature properly.
Subject: Re:Re: Motherboard P6T Deluxe V2
Date: Tue, 20 Mar 2012 15:30:17 +0800
Sorry for my delay.
It is Vt-x.
Andrew
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I'm not sure what CPU you are using (i7-920?), but according to Intel's CPU specs, I don't think that any of the i7-900 series CPUs (socket 1366) are VT-D capable, or are you using a Xeon CPU?
Here's a link to all the Intel CPUs that support VT-D, check the search options on the left of the screen to confirm the seach criteria:
http://ark.intel.com/search/advanced?VTD=true http://ark.intel.com/search/advanced?VTD=true
Intel technical support is really provided here: http://www.intel.com/support/feedback.htm http://www.intel.com/support/feedback.htm
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
From parsec's reply I thought the i7-920 maybe does not support VT-d but the fact that the VT-d column is missing from ARK and not a definitive 'no' is odd.
The update for anyone with this issue on the P6T series is that:
VT-d is working with an i7-920 on a Supermicro board, so this really is ASUS' BIOS problem, and ARK is not telling the complete story about VT-d with previous gen i7 processors.
I'll make a case with Intel technical support.
