I'm currently using an i7-12700F, which to my knowledge is supporting AVX2, but i can't use Programs requireing it, Like Adobe ore EA FC 25.
There should be a setting in the motherboard BIOS that enables or disables AVX2 support. Your BIOS may be different but the screenshot below shows the AVX2 setting for an ASUS motherboard. By default ASUS set this to Auto. If for some reason it does not work on Auto it can be set to Enabled.
Topic Options
