17248 Discussions
About Compute Stick STK2M3W64CC
TAKA_TYO
I'm a user of Compute Stick STK2M3W64CC.
I cannot boot it.
It goes black.
I cannot recover at all.
Please let me know how to do...
n_scott_pearson
Do you see the LED light up and the BIOS splash screen appear when you power it on?
TAKA_TYO
Dear n_scott_pearson,
Thank you for your reply.
Yes, LED light up blue and the BIOS splash screen appear,
 But whem I choose any option it goes black in 5 second..
TAKA_TYO
>Unplug it, hold the power button for 30 seconds, plug back in while still holding, then release after 10 more seconds.
I tried to Hard reset, but It couldn't reset.
>With the stick unplugged, insert USB, hold power button, plug in power while holding.
No, it's same, it goes black...
I tried 3 different power adapter (over 2A), HDMI cable.
AlHill
@TAKA_TYO   Do you not have the original power adapter (the one that came with your stick)?
If I recall, that is the ONLY adapter that will work with your stick (or one that is specifically compatible).  Even though other adaptors have a plug that looks the same, they are not.
[CoPilot is a virus]
TAKA_TYO
Yes, I'm using genuin adapter and genuin cable.
n_scott_pearson
Do you see the Windows loading spinner before the screen goes blank?
TAKA_TYO
Yes, It apears only 5 second before black out.
n_scott_pearson
You're confusing me; let me ask the questions together...
  • Do you see the BIOS Splash screen (where it says 'Intel Compute Stick')?
  • Do you (then) see the Windows loading spinner?
  • Do you (then) have a blank screen?
If your answers are Yes, Yes, Yes, then you likely have a graphics driver that is improperly installed. In this case, you need to boot into Windows Safe Mode, delete the installed graphics driver driver and then reboot. When you get into Windows again, you want to install the latest graphics driver for your stick. This driver is downloadable here: https://www.intel.com/content/www/us/en/download/762755/intel-6th-gen-processor-graphics-windows.html.
If, on the other hand, your answers are Yes, No, Yes, then you likely have a corrupted Windows installation. In this case, you will need to load Windows from scratch, booting from a USB Flash Disk that provides the Windows Installation package. Once you have Windows installed, you need to install the Chipset Device Software package - which you can get here: https://www.intel.com/content/www/us/en/download/19347/chipset-inf-utility.html - and then the graphics driver referenced above.
Hope this helps,
