16762 Discussions
About FH82Q670 SRL01 package dimension .
yip06
Per package specifications package size show 28mm x 25mm , how about the thickness ?
ACarmona_Intel
Hello yip06,
Please allow me time to check your concern internally; I will provide you with an update as soon as I have an answer for it.
By the way, may I know why you wanted to know the thickness of the package? Do you plan to compare it with other packages? etc.?
Carmona A.
yip06
Hi ACarmona ,
Yes , I have plan to compare with other packages .
Will waiting you update for any news
Thank you !
ACarmona_Intel
Hello yip06,
Thank you so much for patiently waiting on my response.
I have verified that the FH82Q670 belongs to the Intel® Q670 Chipset. However, to investigate further, kindly provide the exact processor model that you are inquiring, since the Intel® Q670 Chipset supports numerous processors.
Carmona A.
yip06
Hi Carmona A ,
Chipset  part number is FH82Q670 SRL01 .
Thank you .
ACarmona_Intel
Hello yip06,
Thank you for the response.
What I need is the exact processor model that you are inquiring, since the Intel® Q670 Chipset or FH82Q670 SRL01 supports numerous processors.
Carmona A.
Mike_Intel
Hello yip06,
Michael L.
ACarmona_Intel
Hello yip06,
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Thank you.
Carmona A.
Ernesto_C_Intel1
Hi @yip06
I haven't received your response on this thread. I'll proceed to close this case now.
You can create a new thread to continue your case or contact Intel Customer Support for further assistance
Intel Customer Support: https://www.intel.com/content/www/us/en/support.html
Ernesto C.
