16810 Discussions
Accessing INTEL Atom E6xx GPIO through linux(Inforce Sys9402)
I'm using Inforce computing's SYS 9402 reference platform which has an Intel E6xx processor, for my project. I'm in need of accessing its GPIO pins through assembly language or C. the reference platfom runs Debian Linux distro(linux 2.6.29). Can anyone help me for accessing the GPIO pins?? Please suggest any resources for programming GPIO pins, if any. It's urgent. Please help me :'( .
Thanks in advance,
gouthamraj
Adolfo_S_Intel2
I would suggest checking the Intel programming forums at;
http://software.intel.com/en-us/forums/ http://software.intel.com/en-us/forums/
If they cannot assist you, then I would suggest contacting a Field Application Engineer (FAE).
You can talk to a Field Application Engineer (FAE) by calling any of the Intel Authorized Intel® Distributors, and asking them to put you in contact with a FAE.
Thank you Adolfo_Intel, can you pls direct me how to contact an FAE(because i don't know any Intel Authorized Intel® Distributors)??
Adolfo_S_Intel2
I apologize I forgot to give you that information.
In order to talk to a Field Application Engineer (FAE), please call any of the local Authorized Intel® Distributors, please check this links:
You can find a list of Authorized Intel® Distributors at:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm
If you are outside the United States, please access the following link and select a location, to find the closest authorized distributor:
http://premierlocator.intel.com/Default.aspx http://premierlocator.intel.com/Default.aspx
When calling the Authorized Intel® Distributor, request to talk to a Field Application Engineer (FAE).
thank you for the information...
What did you learn? I am having the same problem.
