16915 Discussions
Adders and Multipliers used in processors
RShin4
I have 2 questions:
1) How many adders and arithmetic multipliers (not clock multiplier) are used in present processors on an average?
2) Is it true that more complex design blocks are less than comparatively less complex design blocks? For example, are number of adders more than number of arithmetic multipliers generally in a processor?
Actually, these questions arose from a doubt regarding constrained resources in hardware.
A programming language code requiring multiplication of two integer/floating numbers actually uses which resource in the processor to do multiplication? Multiplier to do direct multiplication or adder to do successive addition?
In which case the execution is faster? This also includes taking into consideration the continuous switching between programs to achieve multitasking and the waiting time for which a blocked program has to wait for the required resources to be free.
Hello mailto:patelraj773@gmail.com patelraj773@gmail.com,
Thank you for joining our Intel® community.
In this case, please create an account and submit your ticket into our https://www.intel.com/content/www/us/en/design/resource-design-center.html Resource & Design Center
There, one of our community peers will be able to assist you.
I hope this helps.
Diego S.
Intel (R) Customer Support Technician
Under Contract to Intel (R) Corporation
