- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
*9/25/24 - Please go to the following link for the latest updates: Intel Core 13th and 14th Gen Desktop Processor Vmin Instability Issue Root Cause*
Following Intel’s earlier announcement regarding two (2) year warranty extension – from date of purchase, up to a maximum of five (5) years - on Intel Core 13th/14th desktop processors, please see below for additional details on the program.
Intel Core 13th/14th Gen Desktop Boxed/Tray CPUs
The following processors are covered by the warranty extension:
Warranty extension applies to new & previously purchased processors, if they are one of the Intel Core 13th/14th Gen SKUs listed above. This warranty coverage applies to all customers globally.
Standard warranty process and terms apply – which you can review here: https://www.intel.com/content/www/us/en/support/articles/000024255/processors.html.
For users who are or have previously experienced instability symptoms on their Intel Core 13th/14th Gen Desktop processors and need to initiate the exchange process:
- Boxed Processors – please contact Intel Customer Support for further assistance.
- Tray Processors – please contact your place of purchase for further assistance.
- OEM/System Integrator Intel Core 13th/14th Gen-powered desktop system – please contact your system manufacturer for further assistance.
If customers have experienced these instability symptoms on their 13th and/or 14th Gen desktop processors but were unsuccessful in prior RMAs we ask that they reach out to Intel Customer Support for further assistance and remediation.
We appreciate your patience with this process and will continue to share updates relating to the Intel Core 13th/14th Gen desktop processor instability issue.
Enlace copiado
- « Anterior
- 1
- 2
- Siguiente »
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
所以更换产品的质保是重新开始还是跟之前的质保截止日期一样
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
如果是重新开始,那不成永动机了,不可能
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
换了还是13、14代的CPU,工艺决定了这代产品是有缺陷的,这样的产品就应该直接召回而不是换货,换货不能解决根本问题。
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
一个是这玩意不稳定,再一个是换货非常麻烦还可能拒保,再一个换货时间也贼长(但凡用顺丰空运也行啊联邦快递慢的要死),还有 就算给我们退款,那这张主板咋办啊,这不是砸手里了
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
要不然就ultra200出来之后专门给1700平台做一个版本用来售后换新,不然我觉得都是在糊弄
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
怎么都是中国老哥啊,谁知道我的移动端i7-14650hx的质量会不会受到影响啊,会不会用着用着坏了o(╥﹏╥)o
Who knows if the quality of my mobile i7-14650HX will be affected, and whether it will break when I use o(╥﹏╥)o
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Intel insists that the mobile processors like your i7-14650HX are not affected. I have seen any report anywhere by a i7-14650HX owner that they have issues. Intel's mobile processors are always paired with one of the NVIDIA GTX range of mobile chipsets. This makes for a capable combination that is entirely capable of dealing with demanding games.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
反正放假了,闲着也是闲着,不如上网找找乐子
另外这个14650hx好像是跟台式机一样的芯片,所以说我觉得应该也是受影响的,不过这东西,跑测试能过就行,我这用的就是p95第二项,过不了的话就说明你这已经缩肛了或者买来就是坏的
https://www.bilibili.com/video/BV1cK421a7v2/
极客湾这视频大概就把步进说清楚了
至于楼下说的“intel说笔记本不受影响”,我觉得大概率是因为频率相对低 出问题的相对少所以人家单纯不想管
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Typically gaming laptops don't offer the same facilities as desktop processors. So there may be a choice of settings including a Performance option but the ability to change the processor frequency directly through a BIOS setting is less likely to be present. This may vary according to the laptop model so if you have a laptop in mind check the specifications and what reviews say.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
If a model number is not listed in the above table does that mean they do not have the issue identified?
For example the i5-13500T
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
it only means that intel don't admit it have problem...... as far as i know, 13500t may have two kinds of chip,and i just paste another my post for you to reference
yes,if there is no error in 1 hr, the cpu should be ok, then you can try large ffts,its to test ram, if both is fine and no error,i think it will be less likely to be the cpu and ram
and out of my curiousity could you provide a CPU-Z screenshot? I heard that 14400f should have two kinds, and it may could be identify by steeping in CPU-Z, for B0, that is new cores of 13/14th gen, it should have 2mb L2 cache per Pcore on the chip, and been cut to 1.25mb per Pcore, for C0, it is like 12th gen die and have 1.25mb L2 cache per Pcore natively.
if your cpu is B0 steeping, i think it may (only my personal speculate)related to recent "instability issue"
reference:(chinese language video)
https://www.bilibili.com/video/BV19J4m1W7db/
13500t should be similar to this, i think if your chip is B0 stepping, it is likely to be affected
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
My CPU is the i5 13600 ( non k )
here in CPU-Z in code name it says RAPTOR LAKE but in revision i see C0 ( i'm asking becuase i don't know if you were referring to this ) :
in the Mainboard tab i don't see Raptor Lake anymore but Alder Lake :
same in graphics :
i am bit confused if this is alder or raptor lake ( becuase they are both present ) and if it's affected or not by this issue ( and so if i should , when available, update the bios. As you can see from the date in BIOS i think the MB has the "stock" version without any update, since my PC is 1 year old ).
I'm not expert but i don't see any voltage issue or spike for now here in HWINFO ( screenshot after a session of game ) :
I have 0 Issue for now and as said before the PC has almost 1 year.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Correct, that chip is not affected by the overvolting issue.
I would say that the risk behavior starts at 5GHz. That means that there is a theoretical risk of voltages are reaching up to 1.4V for those chips. Intel specifies below 1.55V as safe, I think. My personal limit is 1.3V
In reality the vast majority of issues have been reported for RPL i9K/KS, with some reports for 14700K. 13700K is basically the limit for elevated instability reports. You would find very few unstable chips below that SKU, unless additionally overclocked i5 Ks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Your "personal limit is 1.3V"? Just curious as to where you are coming up with that? Do you have a background in CPU engineering?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Intel has previously stated that all 65W+ base power 13th and 14th gen CPUs are affected. This list you provided excludes e.g. 14600, 14500, 14400F, 14400, 13400, 13400F. Why? Does Intel have new evidence that has led Intel to believe not all 65W+ base power CPUs are affected and thus is updating their previous statement on this? Or is Intel just intentionally excluding some CPUs from the extended warranty?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
As the wording of these updates seem to change every other day, can you please state plainly and simply if the warranty extension covers, without exception, processors that have been bought from OEMs / System Integrators?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Good afternoon
I am a repair technician working for a IT service.
Do you have any suggestions for non-invasive ways to test devices in-mass or otherwise for affected chips.
Particularly something that can detect if the chip needs to be only patched (waiting for patch release) or replaced via OEM RMA.
Like a UEFI USB bootable tool that could be run offline (for security)
Update: 8/9/2024
Will your Intel® Processor Diagnostic Tool be updated to pickup this kind of issue? (last updated in January 2024)*
*Currently it does not, tested it on a buggy i7-13700 this morning.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
- « Anterior
- 1
- 2
- Siguiente »
