16791 Discussions
Affinity issue with Dual Xeon E5-2667 v3 Processor
pprag
Hi All,
Our system configuration is as follows:
CPU Type: Intel(R) Xeon(R) CPU E5-2667 v3 @ 3.20GHz X 2 //Dual CPUs
Motherboard Name: X10DAI
Motherboard Version: 2.0
Total Physical Memory: 65411MB Kingston RAM
BIOS Manufacturer: American Megatrends Inc
SSD: INTEL SSDSC2BW240H6 , 240GB, Intel 535 Series
Operating System: Windows 7 Professional 64 Bit
We have our application(of USB3 cameras,motion cards and IO applications) of 24 thread.When we run on system with both CPU enable sometimes(randomly) it gives error regarding camera bandwidth issue at startup,If no error at startup then there won't be until we stop application.But when we set affinity to either one CPU (run application to only one CPU)then we do not see such error.looks some synchronization issue between two processors.Is there any parameters to take care between two processors from BIOS or elsewhere ?
Thanks in Advance!
Pragnesh Virani
pprag
Can Anyone help out from this problem,Please. Thanks.
Hello, PragneshVirani:
In this case the best support should be provided by your computer manufacturer and this is because from our end the support provided is for desktop chispets controllers since you have server chipset https://www.supermicro.com/about/contact/ Contact Us | About Supermicro - Super Micro Computer, Inc. is the right place in order to get more answers.
Amy.
pprag
Sure, you're welcome.
If you need further assistance let us know.
Amy.
