After double-clicking the DSA installer “Intel-Driver-and-Support-Assistant-Installer.exe”, there is no response at all.
Here are the attempts made:
Tried running Intel-Driver-and-Support-Assistant-Installer.exe with administrative privileges, but still no response.
Tried deleting the C:\ProgramData\Intel\DSA folder, running DSAUninstaller.exe, and then restarting the computer, but still no response after double-clicking.
Hello Victoire,
Thank you for reaching out and for providing the video of the issue being encountered with the installation of the Intel Driver Support & Assistant.
I would like to clear the following questions:
- Did you make recent changes to the system?
- Was this installable before?
- Do you have sufficient storage?
- Have you tried ending the process of IDSA on task manager manually and relaunching the installer?
- Do you encounter error codes?
I look forward to your response!
Robbie R.
No, I didn't.
Yes.
Yes.
Yes.
No, it didn't pop up any window.
Hello Victoire,
I wanted to check in and see if you had a chance to go through the questions I shared earlier. Whenever it’s convenient for you, just let me know; I'm happy to continue assisting you.
Robbie R.
Hello Victoire,
I'm glad that you were able to answer the following questions I have provided. It is understood that your Intel Driver Support & Assistant was working fine before. With that being said, please try this recommendation:
Steps to completely uninstall the Intel® Driver & Support Assistant (Intel® DSA):
- Open a new tab on any web browser (Firefox, Chrome, or Edge.).
- Download and run the Intel® Driver & Support Assistant Uninstaller .
- Accept the terms & conditions.
- Click on Next.
- Click on Close.
Once uninstalled, please ensure to reinstall the IDSA. However, if the above recommendation did not work, please answer the following questions:
- Are there any anti-virus installed on your system? What is the anti-virus software?
- Do you currently have third party driver updaters installed in your system?
- What were the recent changes on the system? (Windows Updates, New Applications installed, etc)
Robbie R.
It still doesn't work.
Only windows defender.
No.
Last time I installed the IDSA is nearly a year ago. I didn't change my system recently.
Hello Victoire,
I hope you had the opportunity to review the information I posted. At your earliest convenience, please let me know so we can determine the best course of action to resolve this matter efficiently. In line with this, I would like to request for the IDSA logs and SSU logs.
Archie D.
Hello Victoire,
Thank you for your response. I'm glad that you were able to reply.
To confirm, I want to know if you did a Uninstallation and Installation of the Intel Driver Support & Assistant application?
Additionally, please provide the the IDSA logs and SSU logs to further check your system.
Additionally, may I know what is the driver that you would want to download?
Robbie R.
Hello Victoire,
I wanted to check if you've had a chance to review my colleague's previous response. Please provide the requested information at your earliest convenience.
Dhanniel M.
Hello Victoire,
Since I haven't received a response from you, I will proceed to close this inquiry. If you require further assistance, please feel free to submit a new question, as this thread will no longer be monitored. Thank you for your understanding.
Dhanniel M.
