16851 Discussions
Are the Thermal conductivity and cooling performance of stock fans E97379-003 and E97379-001 the sam
amd_lover
The Delta E97379-003 fan is the stock fan that comes with the Intel i7-7700.
The Delta E97379-001 fan is the stock fan that comes with the Intel i3-6100.
The technical data page only has data for the E97379-003. There is no information about the E97379-001.
https://www.intel.com/content/www/us/en/support/articles/000055841/processors.html
If you examine the PDF file for Delta production E97379-003, you will see the thermal conductivity value.
https://www.intel.com/content/dam/support/us/en/documents/processors/E97379-Delta-Datasheet.pdf
Delta's E97379-003 has a thermal conductivity value of 4.3 W/m-°C.
What is the thermal conductivity value of Delta's E97379-001?
Do both fans have the same cooling capacity?
The reason I'm asking this question is that my computer has an Intel i3-6100 and a Delta E97379-001 stock fan installed.
I bought a second-hand i7-7700 processor. It didn't come with a stock fan. I have no choice but to use the Delta E97379-001 stock fan.
As a result of my research, the stock fan for the Intel i7-7700 is the Delta E97379-003.
Are the aluminum cooling fins and fan motors of the Delta E97379-003 and Delta E97379-001 cooling systems the same? Are the fan speeds the same? Are the air flow rates the same? Are their thermal conductivities the same? Do these cooling systems have the same cooling performance?
Is there only a version difference? Is there a difference between the 001 and 003 versions?
