16761 Discussions
Asus Z97-PRO GAMER Intel Z97 LGA 1150 ATX
EMagn
Hello! I am not find in your Compatible Mainboards list> Asus Z97-PRO GAMER Intel Z97 LGA 1150 ATX mainboards. http://www.asus.com/Motherboards/Z97PRO_GAMER/ http://www.asus.com/Motherboards/Z97PRO_GAMER/.
At list have just Z97-PRO.
This mainboards work good with i5 4690 3.5 GHz LGA1150 or Intel Core i5 4690K 3,5 GHz prossesors?
thank you!
Amy_C_Intel
Hello Dies-diem-docet,
The Intel® Core™ i5-4690K and the Intel® Core™ i5-4690 were released prior to the motherboard that's why Intel could not test them at that time. However you can refer to the following link http://www.asus.com/Motherboards/Z97PRO_GAMER/HelpDesk_CPU/ http://www.asus.com/Motherboards/Z97PRO_GAMER/HelpDesk_CPU/, it shows the supported CPU's for this motherboard and they are both compatible.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy.
