16968 Discussions
BIOS update on intel DH77EB motherboard
marcosdangelo
I have a desktop running on a DH77EB motherboard and i tried to install a newer graphics card.
The mb does not recognize it.
I want to update the BIOS but can't find the files on intel website.
Anyone has the latest version of the BIOS for this motherboard?
AlHill
You can download the latest/last bios (0103) and release notes from here:
https://web.archive.org/web/20191119131212/https://downloadcenter.intel.com/download/24426/BIOS-Update-EBH7710H-86A-?product=59505
AlHill
marcosdangelo
@AlHill Thank you! Just what i needed.
AlHill
Which graphic card did you use, and did it work?
marcosdangelo
Im going to install a NVIDIA T400. My current BIOS version is 53 so i had update via USB. Still installing bt will update as soon as I make it work.
AlHill
I am not familiar with that card.  However, with old boards, I have seen success with older nvidia cards.  AMD cards rarely work.
Remember, that board is a decade old, so compatibilty of newer cards is hit or miss.
marcosdangelo
@AlHill it worked!
I have 2 desktops with this mb.
One i was successful in updating the bios and the graphics card worked perfectly.
Now i'm having issues in updating the bios in the other one. Intel Management Engine Firmware failed to update. But that's a different matter.
But despite the problems, at least one desktop is working.
Thank you for your help!
AlHill
Glad the T400 worked.   For the board with the ME problem, try bios recovery if the F7 bios update is failing.
marcosdangelo
Copied the .bio file to a clean formatted (Fat32) USB stick, removed the BIOS mode jumper and switched the pc on but nothing happened.
I don't know why, but the BIOS is not entering recovery mode.
AlHill
Did you use one of the black usb ports on the rear of the board?
marcosdangelo
Yes. Tried all the usb 2.0 ports
AlHill
Hmmmm...  Maybe @n_scott_pearson  can shed some light on this?
n_scott_pearson
Was it a true USB 2.0 flash drive?
AlHill
Also, replace the battery for good measure.
marcosdangelo
@n_scott_pearson  it was. An older USB flash drive i have.
@AlHill first thing I did.
I tried to update using ms dos but somebody bumped on the power plug and corrupted the bios. I bought a EEPROM flasher to try to recover it now. Waiting for it to be delivered. Will post an update as soon as I can.
hk16
Respected Sir,
i have intel DB75EN motherboard and need to bios update if possible, please give me an idea i have no bios source available, if you have just give me.
thnak you
AlHill
Go here:  https://web.archive.org/web/20191119131119/https://downloadcenter.intel.com/download/22943/BIOS-Update-ENB7510H-86A-?product=59043
[Fear and the desire for control are primary motivators for shadow dwellers. ]
