16771 讨论
Black screen after enabling "Intel virtual technology" HELP!!!!!
ddokk
初学者
4,126 次查看
My laptop won't boot (Lenovo z400, gt740m edition) after enabling VT on my BIOS, it won't boot in safe mode or acces to the BIOS. Also I installed LucidLogix Virtu Mobile. Keyboard wont respond, Bloq mayus light wont turn on.
Specs:
Nvidia gt740m (331.82 driver) and Intel HD4000 (latest driver)
4gb ram
i3 3110m
windows 8.1
thanks
0 项奖励
2 回复数
ddokk
初学者
3,265 次查看
PROBLEM SOLVED!!!!!!!!
THE PROBLEM:
The problem wasn't intel virtual technology, the problemas was Lucidlogix's virtu mvp, because this software unlocks your BIOS and let you change stuff you shouldn't change, corrupting the BIOS
THE SOLUTION:
Since you can't extract the battery of the Z400 to do the bios reset trick, I had to figure out another way to do it.
1. Unplug AC adapter
2. Connect every usb power consumer in laptop's ports (phone for example)
3. When battery runs out of charge keep trying turning on your laptop, until the battery led won't flash anymore
4. When the battery is completely discharged, press and hold the power button for 10 seconds (I did this 3 times every 10 minutes to be 100% sure)
5. Plug your AC adapter and boot normally
6. Never touch your BIOS again!!!!!!!!!!!
0 项奖励
Kevin_M_Intel
员工
3,265 次查看
Thank you for the information provided. I am sure this will be very helpful for other users with this problem.
0 项奖励
回复
