16790 Discussions
Braswell N3010 power sequence problem
KChen85
I have a question about N3010 power sequence.
We power up the system without BIOS code, the PMIC is TPS650842 from TI. I check the voltage rail and sequence by scope, every rail is right. But after PMIC pull up VCCAPWROK & COREPWROK, the N3010 didn't pull up PLTRST(SLP_S3_N already pulled up by N3010). Is it no BIOS code cause this problem?
thanks,
Kevin
Hello KevinChen:
In order to proper assist you with the information you are requesting, please submit your inquiry in our developer zone, they should be able to assist you with all the details you need about the power sequence on the processor.
Here is the link for the developer zone forums:
https://software.intel.com/en-us/forum https://software.intel.com/en-us/forum
Alberto
KChen85
Hi Alberto,
I don't know which forum is about the hardware or Braswell platform. Which forum shall i ask for help?
Kevin
Hello KevinChen:
I just wanted to let you know that I sent you a private message, so, if you are able to reply to it with the information requested in there, we would really appreciate that.
Alberto
Hello KevinChen:
Thank you very much for that information, we really appreciate that you took the time to provide those details.
Now, I was doing some research and actually in order to get the information you are requesting, you just need to join the forums from our Intel® embedded design center, in there, even if you do not see a subject related to what you need, you can create a new thread, they should be able to assist you in there:
https://embedded.communities.intel.com/community/en https://embedded.communities.intel.com/community/en
Also, you can always register on the following site to get even more information about this matter:
https://www-ssl.intel.com/content/www/us/en/secure/forms/design-assistance.html https://www-ssl.intel.com/content/www/us/en/secure/forms/design-assistance.html
Alberto
