16774 Discussões
BugCheck 124 GenuineIntel 7820X BSOD
ROkol
Principiante
9.954 Visualizações
Would greatly appreciate if someone could help debug this BSOD issue, I'm at a loss.
Bought the Intel i7 7820X and been battling with BSOD when I run a specific application, Counter Strike GO, with a stop code of 0X124
Thought I resolved this by updating all the vendor drivers, bios, and uninstalling unnecessary software.
The application was able to run without causing to BSOD at launch after the Motherboard bios update and was usable.
However - application crashed to desktop intermittently - debugDaig dump pointed to phonon.dll and Xaudio7_2 (Microsoft DLL)
I opened a ticket with Valve and they passed it onto the dev team.
Now, the other day I started to experience the same problem as before with BSOD at launch with BugCheck 124 caused by GenuineIntel.
Having a lot of problem pointing out the root cause and I would like to attach my dump with !analyze -v
I Ran Prime 95 for 10 hours straight with CPUMEM test without issue.
One thing that sticks out is the following in the dump, tho I could be wrong.
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: f
Please provide some feedback or advice. Thank you!
SPECS
Windows 10 Build 16299.431
Intel Core i7 7820X CPU_MICROCODE: 6,55,4,0 (F,M,S,R) SIG: 2000043'00000000 (cache) 2000043'00000000 (init)
Asus Rampage Apex VI BIOS_VERSION: 1301
32GB DDR4 3600 F4-3600C16-8GTZSW
Nvidia GTX 1070 TI 3.13.1.30
Crucial CT1050MX300 SSD
Temp 39C Idle 75C 100% Load (with AC)
13 Respostas
ROkol
Principiante
6.917 Visualizações
Updated Information +Append to debug log
1: kd> dt nt!_WHEA_ERROR_SOURCE_TYPE
WheaErrSrcTypeMCE = 0n0
WheaErrSrcTypeCMC = 0n1
WheaErrSrcTypeCPE = 0n2
WheaErrSrcTypeNMI = 0n3
WheaErrSrcTypePCIe = 0n4
WheaErrSrcTypeGeneric = 0n5
WheaErrSrcTypeINIT = 0n6
WheaErrSrcTypeBOOT = 0n7
WheaErrSrcTypeSCIGeneric = 0n8
WheaErrSrcTypeIPFMCA = 0n9
WheaErrSrcTypeIPFCMC = 0n10
WheaErrSrcTypeIPFCPE = 0n11
WheaErrSrcTypeGenericV2 = 0n12
WheaErrSrcTypeSCIGenericV2 = 0n13
WheaErrSrcTypeMax = 0n14
1: kd> .frame /r 3
03 ffffae80`9124be60 fffff803`08b1a440 nt!WheaReportHwError+0x261
rax=0000000000000000 rbx=ffff9a07af5b0028 rcx=0000000000000124
rdx=0000000000000000 rsi=ffff9a07ae6f22b0 rdi=ffff9a07ae6f22b0
rip=fffff8030848d781 rsp=ffffae809124be60 rbp=0000000000000000
r8=ffff9a07af5b0028 r9=00000000b2000000 r10=ffff9a07af5b0148
r11=0000000000070005 r12=ffff9a07b7e5db09 r13=ffff9a07ae9a0b58
r14=ffff9a07af5b0000 r15=0000000000000000
iopl=0 ov up ei pl nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00000a06
nt!WheaReportHwError+0x261:
fffff803`0848d781 eb70 jmp nt!WheaReportHwError+0x2d3 (fffff803`0848d7f3)
1: kd> .bugcheck
Bugcheck code 00000124
Arguments 00000000`00000000 ffff9a07`af5b0028 00000000`b2000000 00000000`00070005
1: kd> dt _WHEA_ERROR_PACKET_V2
nt!_WHEA_ERROR_PACKET_V2
+0x000 Signature : Uint4B
+0x004 Version : Uint4B
+0x008 Length : Uint4B
+0x00c Flags : _WHEA_ERROR_PACKET_FLAGS
+0x010 ErrorType : _WHEA_ERROR_TYPE
+0x014 ErrorSeverity : _WHEA_ERROR_SEVERITY
+0x018 ErrorSourceId : Uint4B
+0x01c ErrorSourceType : _WHEA_ERROR_SOURCE_TYPE
+0x020 NotifyType : _GUID
+0x030 Context : Uint8B
+0x038 DataFormat : _WHEA_ERROR_PACKET_DATA_FORMAT
+0x03c Reserved1 : Uint4B
+0x040 DataOffset : Uint4B
+0x044 DataLength : Uint4B
+0x048 PshedDataOffset : Uint4B
+0x04c PshedDataLength : Uint4B
1: kd> dt nt!_WHEA_ERROR_TYPE
WheaErrTypeProcessor = 0n0
WheaErrTypeMemory = 0n1
WheaErrTypePCIExpress = 0n2
WheaErrTypeNMI = 0n3
WheaErrTypePCIXBus = 0n4
WheaErrTypePCIXDevice = 0n5
WheaErrTypeGeneric = 0n6
ROkol
Principiante
6.917 Visualizações
1: kd> !errrec ffff9a07af5b0028
Common Platform Error Record @ ffff9a07af5b0028
Record Id : 01d3e754afc65745
Severity : Fatal (1)
Length : 864
Creator : Microsoft
Notify Type : Machine Check Exception
Timestamp : 5/10/2018 1:23:23 (UTC)
Flags : 0x00000000
Section 0 : Processor Generic
Descriptor @ ffff9a07af5b00a8
Section @ ffff9a07af5b0180
Offset : 344
Length : 192
Flags : 0x00000001 Primary
Severity : Fatal
Proc. Type : x86/x64
Instr. Set : x64
Error Type : Micro-Architectural Error
Flags : 0x00
CPU Version : 0x0000000000050654
Processor ID : 0x0000000000000001
Section 1 : x86/x64 Processor Specific
Descriptor @ ffff9a07af5b00f0
Section @ ffff9a07af5b0240
Offset : 536
Length : 64
Flags : 0x00000000
Severity : Fatal
Local APIC Id : 0x0000000000000001
CPU Id : 54 06 05 00 00 08 10 01 - bf fb fe 7f ff fb eb bf
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
Section 2 : x86/x64 MCA
Descriptor @ ffff9a07af5b0138
Section @ ffff9a07af5b0280
Offset : 600
Length : 264
Flags : 0x00000000
Severity : Fatal
Error : Unknown (Proc 1 Bank 0)
Status : 0xb200000000070005
Funcionário
6.917 Visualizações
Hello Middleman,
I understand that you are currently experiencing BSOD when running the game Counter Strike GO.
Regarding this, I would like you to run a diagnostic on the processor using our software Intel ® Processor Diagnostic Tool, after the diagnostic is complete, please post the results here. You can download the software by accessing the link below:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Also, if possible, re-install the game completely by deleting all of the files from the system and once re-downloaded, check if the issue persists. I also want to know if this error is happening only with that game, have you tried other games/applications?
Let me know please.
David V
ROkol
Principiante
6.917 Visualizações
Thanks for the response and link, ran the tool and can provide the results.
Now to answer some of your prior questions - crash seems to happen just with Counter Strike Go.
I've also tried to reinstall the application, and removed unnecessary apps.
No other application has caused bsod.
I'm thinking its related to Valves phonon.dll and Microsoft's Xaudio2_7.dll - though bsod shouldn't happen. So not sure if its the micro code or drivers.
Before I upgraded my motherboard bios though, I had some issues with Windows Sleep Mode / Power Management
For example, booting back from sleep - the computer was unresponsive -usb ports, mouse keyboard unresponsive and screen was black (orange led)
Had to hard reboot to bring back the OS. Seems fine now after 13XX bios - and i've switched to hibernate mode.
Funcionário
6.917 Visualizações
Hello Middleman,
Thank you for your response,
To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
Also, if possible please attach screenshots or pictures of the BSOD with the error.
David V
ROkol
Principiante
6.917 Visualizações
Hello, I am going to attach the DXDIAG output to this reply.
The only info regarding bsod is the attached memory dump from before.
Windows 10 present a generic QR code.
Funcionário
6.917 Visualizações
Hello Middleman,
Regarding this issue, we are going to do the following: Please download the Intel ® Extreme Tuning Utility from the link below:
https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU- Intel ® Extreme Tuning Utility.
Once downloaded and installed, reboot the computer and then open the tool. Take a screenshot of the idle state of the processor, in other words, just with the application open. After that, please run a stress test for 5 minutes and see if it succeeds, if it does, please take another screenshot and attach it to the thread, if not, please let me know.
David V
ROkol
Principiante
6.917 Visualizações
Hello David,
I've gone ahead and installed/ran the utility, going to post the two screen capture's.
ROkol
Principiante
6.917 Visualizações
Experienced another BSOD today, latest memory dump.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Kernel address space is available, User address space may not be available.
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 16299 MP (16 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 16299.431.amd64fre.rs3_release_svc_escrow.180502-1908
Machine Name:
Kernel base = 0xfffff802`9d209000 PsLoadedModuleList = 0xfffff802`9d56f030
Debug session time: Wed May 23 15:16:26.252 2018 (UTC - 4:00)
System Uptime: 9 days 3:47:05.083
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000000`004a5018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, ffffd3025f1b8028, f2000000, 70005}
Probably caused by : GenuineIntel
Followup: MachineOwner
4: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffd3025f1b8028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000f2000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000070005, Low order 32-bits of the MCi_STATUS value.
Funcionário
6.917 Visualizações
Hello Middleman,
Thank you for your response.
I would like to know if you have overclocked this processor. This is because the BSOD could be happening due to the processor being overclocked as well, since this is a possibility I would like to ask this. If not, please let me know.
David V
Funcionário
6.917 Visualizações
Hello Middleman,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
ROkol
Principiante
6.917 Visualizações
Hello - yes with the Asus Rampage Apex VI - The system has a default overclock of 4ghz.
Want to update you with regards to stability issue. Seems to be resolved now.
I am no longer experiencing BSOD and Application crash of CSGO.
It is possible that Valve released an update as per my support ticket with them.
NOne01
Principiante
6.917 Visualizações
Hello! Could you help me, I have the same problem: Notebook Xiaomi gtx with i7 8550u
Windows 10 crashed to BSOD intermittently. I asked on Microsoft forum, but they directed me to here.
I already ran Intel ® Processor Diagnostic Tool, results and minidumps in attachment.
Also I ran AIDA stress test, windows memory test and I tested ssd - each one was good.
Responder
