16785 Discussions
CPU Clock Signal is from Motherboard or from CPU
RichardSim
Dear Intel,
I would need your help to clarify the following.
We knew the computer system needs a clock signal. The clock signal is generated by motherboard or CPU?
If the clock signal is generated by CPU, can you help to slightly explain how the clock signal is generated? I knew how a CPU IC chip is created. I cannot understand how the CPU chip is able to create the clock signal?
RamyerM_Intel
Hello RichardSim,
Thank you for posting in the communities. To answer this more specifically for you, do you have specific CPU in mind? May I please know why you need this information? I ask because I want to know if you are developing a software. Just to make sure we are on the same page, can you please clarify what you mean for CPU IC? I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello RichardSim,
How are you doing? I am just following up about the specific model of the CPU. Kindly please share the information we have asked in my previous post so we can better assist you. I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello RichardSim,
I hope you are doing well. As we have not heard a response in the past few days, we will proceed in closing this thread. If you need additional information, please submit a new question as this thread will no longer be monitored.
Ramyer M.
