16891 Discussions
CPU Temp Max state in settings
Bun
Hi   is   setting   the   max  cpu state   to 99%         going to     damage it   or have any  negative        actions   on my hardwar         MSI GF75 Thin    I7 10750 H      RTX 3060
Because   the temp is realy high   95C   whyle gaming and sometimes just by using chrome or any other task   it go  up to 90C                  Even if using fan boos mode in dragon center
PLZ HELP
DeividA_Intel
Hello Bun,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Core™ i7-10750H Processor.
1. Where are you seeing the temperatures? Can you take a picture?
2. Are you using a laptop or desktop computer?
3. Are the fans spinning?
4. Is this issue recent? If so, when did it start?
5. Is the unit stack at 95 degrees for long periods of time or are they only spikes?
Deivid A.
Bun
         Laptop    MSI GF 75 Thin       using dragon center
    Whyle gaming the temps are above 90c allthe time     ++++     Max Fans Active
i don't know if this issue is recent or not  sorry i cna't remember anything   becaure when i got this pc i was using silent mode and i never cheked the temps this summer when i started gaming on it i started using balenced mode or bosst mode   and i paid atention to the temps ....
'//Whyle gaming the temps are above 90c allthe time     ++++     Max Fans Active
'//doing simple tasks  it changes from 50 to 90  like watching youtube        openng a new tabs in chrom   then it gets stable at 60 C       but as soon as i click on somthing you hear the fans spining for 6s  then back to 60C               and    undervolt is blocked  + i dont want to do it cause i think ill damage my pc
'//and i dont think the chip is damaged at all because in task manager i get up to 4.5 Ghz
                     The thing is what i want is a safe method to make the processor not getting hot by just youtube or chrm tabs   because i know that this cpu  can do a lot of things just by the base clock    there is no need to go up to 4Ghz then to 1.2Ghz becuse i tried detting the max state at 99% and the cpu was cool
PLZ HELP Sir   Deivid A          . Bun
DeividA_Intel
Hello Bun,
Thanks for the information provided. Based on your system I recommend you to try the following:
1. Try to load your BIOS to default settings.
2. Make sure with MSI that you have the latest BIOS installed
3. Make sure that there is no obstruction in the laptop vents.
However, the best recommendation is to check with MSI to confirm that the thermal paste is properly applied and the colling solution is working properly. Bear in mind that this is a highly customized system and MSI may need to inspect your laptop's hardware to make sure that everything is working properly.
Deivid A.
Bun
Thanks For your answer ill try those steps
but still my   question  will             setting the max cpu state to 99% damage it
DeividA_Intel
Hello Bun,
Thanks for the confirmation. I will be waiting for the results of these steps.
Based on your CPU specifications, your CPU can support up to 100°C, and any temperature above that or if the temperature is stocked above this will damage the processor and the laptop too.
Deivid A.
DeividA_Intel
Hello Bun,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
DeividA_Intel
Hello Bun,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
Bun
You didn't tell me      will    setting the max cpu state to 99% damage it   not ////the temmp
you know the setting in control panel
