17052 Discussions
CPU not running as expected
KirinCooper
My CPU (i7-14700K) is failing to boost to 253W or reach 100C, as a result I am unsure as to why my CPU is not running at 253W under load, so far this is the data I have
RamyerM_Intel
Hello KirinCooper,
I noticed that you are using a third party app called Cinebench. Kindly please use our Intel Xtreme Tuning Utility instead if you are trying to overclock, monitor and stress your system. You may download it at this link: https://www.intel.com/content/www/us/en/download/17881/intel-extreme-tuning-utility-intel-xtu.html
Also, are you experiencing any issues in your current setup?
Ramyer M.
KirinCooper
I have also used Intel XTU, with the same results, maxing out at about 150W with an average of about 65, at any rate that hasn't changed the results, and I am looking for the solution, I am not looking to overclock, simply to see the 253W (and related performance) or explain why I can't and how to solve it
RamyerM_Intel
Hello KirinCooper,
Since you mention that you are maxing out at about 150W with an average of about 65, Kindly please send us a screenshot of the Intel XTU settings  so we can further  investigate this for you.
Ramyer M.
KirinCooper
Intel XTU gets better results, a zipped video of the results is included below
KirinCooper
That is to say better but from what I can tell still not as high as one would expect
KirinCooper
Furthermore I think this better shows what I mean
KirinCooper
The 100C does refer to temperature
AlHill
@KirinCooper   You do not have to keep making one-line posts.   There is an edit feature for you to modify a post.
KirinCooper
Apologies, for the for the data that isn't relevant, here is a screenshot of XTU settings
RamyerM_Intel
Hello KirinCooper
We'll be checking this information with our team for now and keep this thread posted for updates.
Ramyer M.
RamyerM_Intel
Hello KirinCooper,
Upon checking this case, we would also like to suggest checking some settings in XTU, such as PL1 and PL2. Also, we've reviewed the video that you sent us and we noticed that the processor was running at 5.09 and one point 5.29 GHz. Based on our observation from the video, the processor is functioning well. Moreover, we can see power limit throttling turns "red". We hope that you are using all the compatible peripherals, especially PSU and Cooler.
Additionally, we have tested the following configuration during our simulation:
1. All set to "auto", CPU max temp set to 100C, MCE (multi-core enhancement) disabled => power draw over 240W and decreasing to 150-170, because of inefficient cooling, CPU temp quickly goes to 100.
2. PL1 & 2 set to 250W, CPU max temp set to 100C, MCE disabled => power draw over 220W for a short time, then decreasing to 150-170, CPU temp 90-95C.
3. PL1 & 2 set to 250W, IccMax set to 280A, CPU max temp set to 100C, MCE disabled => TDP around 150-160W and lower, CPU temp around 85C (stable)
Setting IccMax to 280A (value from datasheet) pretty much covered all other limits for CPU. Changing just this value while PL1/2 is set to 250W will change CPU performance.
Ramyer M.
KirinCooper
I suspect that the cause may be the motherboard then, in bios I have PL1 and PL2 set to 253, however the motherboard is the (MSI) H610M-B, although I'm not sure whether that can be resolved in bios, the cooling solution says Air tower cooler (PL1:100W) although my PL1 is set to 253W, so I think that may be it, but I'm not sure because the CPU exceeds 100W and as such I am unsure as to how to resolve the issue
KrissyG
New Contributor II
(MSI) H610M-B? does it look like this?
The one i found has no MOSFET heatsink, not even one, i highly doubt that without any heatsink thee MOSFETs can take even 100W for a longer period of time.
KirinCooper
That is the motherboard, would I need to get a new motherboard then? That seems to be the solution
RamyerM_Intel
Hello KirinCooper,
I noticed one of our community member also replied in your message. We highly encourage responding to it as well as they might also share some helpful information with you. For now, I just want to confirm, were you able to try the troubleshooting recommended? How did it go?
Ramyer M.
KirinCooper
I'm not entirely sure, it seems from this information that I will need a new motherboard, although that may be incorrect, I suspect it is accurate
KrissyG
New Contributor II
If the MOSFETs would overheat, a thermal throttling would take place. Since i have no idea where you could look it up, i will suggest installing Hardware Monitor, run some stress test or benchmark and watch the temperatures that it shows.
The highest temperature usually is the CPU, second highest will be the MOSFETs.
You should not be seeing any values close to +100°C on the MOSFETs.....in fact, none of the shown values should reach that temperature even after few minutes, else thermal throttling will take place.
In my caseTMPIN4 are the MOSFETs, for you it may be one of the other values.
RamyerM_Intel
Hello KirinCooper,
How are you doing? I understand that you have some doubts whether the issue is with the motherboard, trying out the troubleshooting would enable us to further narrow it down. I just want to confirm, what were the results when you have tried the troubleshooting we recommended? Since the motherboard is an Original Equipment Manufacturer Device, have you also reached out to Gigabyte?
Ramyer M.
KirinCooper
I checked BIOS and PL1&2 are high, but tower cooler forces the PL down I think, I did try to get support from MSI as well, although I have not seen a response
RamyerM_Intel
Hello KirinCooper
I am sorry to hear about the non response from MSI. Since that is the case, kindly please provide us your SSU logs so we can examine your system configuration and specification more closely. You may download it at this link:https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html.
I also noticed one of our community membesrs, KrissyG suggested checking the cooler profile parameter. Upon conducting further research I want to let you know that MSI motherboard has a feature called "CPU cooler tuning" that can affect the power limit on the motherboard depending on the chosen setting. We kindly ask if you can turn off this feature or choose a setting that matches or exceeds their cooler TDP and then adjust PL1&2 values accordingly. Here is a YouTube video that might be helpful to follow: https://www.youtube.com/watch?v=571w897Ix9o. However, I want to set your expectation that it is best if you can coordinate this feature with MSI since they the Original Equipment Manufacturer of this motherboard, and they are much more familiar with the features and specifications of this system.
Nonetheless, we will still try to assist you. Feel free to reply here with your SSU Logs
Ramyer M.
