16806 Discussions
CPU not running as expected
KirinCooper
My CPU (i7-14700K) is failing to boost to 253W or reach 100C, as a result I am unsure as to why my CPU is not running at 253W under load, so far this is the data I have
KrissyG
New Contributor II
'PerfDrive' is the name of the said setting for Gigabyte (default is 'Optimization') and Gigabyte actually advertises their products in BIOS, bcoz the mentioned water coolers are their products.
RamyerM_Intel
Hello KirinCooper,
How are you doing? Did MSI replied with you? I sent you a post before asking for your SSU logs. Feel free to send it here if you still need assistance.
Ramyer M.
RamyerM_Intel
Hello KirinCooper,
I hope everything went well with MSI. As we have not heard a response from you, we will proceed in closing this case. Should you need further assistance, please post a new question as this thread will no longer be monitored.
Ramyer M.
