CPU
PDale1
Is my CPU going faulty have downloaded the Intel processor diagnostic tool 64Bit.running a test it states a FAIL on the band string test processor 1,is it anything to be worried about? can it be fixed?am running Windows 10 OS 64bit sometimes the laptop freezes but have a new 1TB HDD good cooling pad along with anti-virus and antispyware which are always up to- date.
Not applicable
Hi PeterJD,
Intel® Processor Diagnostic Tool is telling you the processor is faulty; however, we need to narrow the issue. Make sure the memories are running at the proper speed.
If problem continues, I will suggest you to contact your pc manufacturer and try to replace the laptop.
Now, Windows® 10 works better on computers with 4th generation processors; the error could be a compatibility issue.
Mike C
Not applicable
Hi PeterJD,
Mike C
