16841 Discussions
CPUFreq and BrandString tests are failing
hkhandelwal
Hi
I recently got a new PC build. After playing some fps games they started crashing in between with random critical error. After running intel processor diagnostic tool, got above two mentioned test failed. Attaching system info and failing ss.
hkhandelwal
Steven_Intel
Hello hkhandelwal,
I appreciate the troubleshooting steps performed already. In order to better assist you, please provide the following information:
- Are all games getting that error? If the issue happens with just some games, please specify which.
- Was there any recent software or OS update before the issue started? Or has it been like that since the beginning?
As well, could you please attach the Intel® Processor Diagnostic Tool results file? You just need to run the test, then go to File > See results file, and then attach it to your reply.
I look forward to hearing from you.
Steven G.
Steven_Intel
Hello hkhandelwal,
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
