16771 Discusiones
CPUTIN/AUXTIN/Processor temperatures way to high ? - i5 2400 + Asus p8h61 evo evo
Empleados
7.250 Vistas
Hi, I just assembled my first system ever. My basic kit is : Asus P8h61 evo + i5-2400 + my old pny 8800GT gfx card on top of it. It's the first time I put a computer up by myself so all of this is new to me, I'm still learning about checking if I've done things the right way...One of the first things I checked was obviously system temperatures.The Asus AI Suite II indicates my CPU temp is 26C (I couldn't find the detail per core, I don't know if it is available) and Motherboard is 24C, which all sounds ok. http://i.imgur.com/YYnGa.jpg http://i.imgur.com/YYnGa.jpgHowever, I installed 3 other softwares : Hardware monitor, AIDA and Speedfan to test my system temperatures in a more detailed way (I ran them separately so one program would not influence the other). Individual core temperatures seem to be ok butaccording to those 3 programs, Processor/CPUTIN/AUXTIN temperatures are too high to be normal (see the highlighted info in the linked screenshots) for detailed information.[img]http://i.imgur.com/X4NpB.jpg http://i.imgur.com/X4NpB.jpg[/img][img]http://i.imgur.com/ASVnM.jpg http://i.imgur.com/ASVnM.jpg[/img][img]http://i.imgur.com/jtA0E.jpg http://i.imgur.com/jtA0E.jpg[/img] Those temperatures are definitely weird and since nomenclature seem to change in between softwares, it's a bit hard to know which one is which. Anyway, it's easy to see they are not normal.Is it a problem with the way the information is collected/calculated by the motherboard/processor interface or could it be a real issue with one of those items (or some other ?) Some people told me that only the core temperature information were relevant but nobody seemed to know the exact reason why those Processors/CPUTIN/AUXTIN temps appear to be so high.My pc has worked perfectly fine for the past 5-6 days but these figures seem strange and not being tech-educated, I do not know where they come from, how they are calculated, and if I should worry about it all or not (and eventually send the motherboard and/or processor back?)...I'd be happy not to fry my new system Some extra info about my build :I have the intel oem fan and heatsink above the cpu.5 extra fans inside the case (4 linked to the case, 1 to the mobo), split this way :Blowing air in the case : 2 in front , 1 on the side panel towards the gfx card and processorBlowing air out of the case : 1 on top, 1 in the (upper) back Any idea/suggestion about what I should do ?
0 kudos
4 Respuestas
Adolfo_S_Intel2
Empleados
5.580 Vistas
Keep in mind that you do not need to worry about cores temperature, you only need to pay attention to the CPU temperature itself.
In this particular case, the maximum recommended temperature for the i5-2400 is 72.6 degrees Celsius as showing here:
http://ark.intel.com/products/52207/Intel-Core-i5-2400-Processor-(6M-Cache-3_10-GHz) http://ark.intel.com/products/52207/Intel-Core-i5-2400-Processor-(6M-Cache-3_10-GHz)
So as long as the processor runs below that temperature, it will be running under thermal specifications.
Empleados
5.580 Vistas
But do you know where this CPUTIN/AUXTIN temperatures come from ?
In this link
Processeur (processor = CPU ?) is at 88C
whereas CPU Package and core temperatures seem to be ok...so I don't know which one is relevant (and why "processeur" is so high)
In that link
CPUtin and AUXtin are way too high. They seem to be linked to the motherboard (whereas in the above link, the problem was in the CPU section)
And in this one
Both CPU and AUX are problematic.
So I really don't know what to do with all of this except fear sthg is wrong and my system is gonna melt at any moment.....
Empleados
5.580 Vistas
The CPUTIN and AUXTIN readings are nothing to worry about. They are strange readings that some monitoring programs display, I have seen them before many times. I'm not sure where they come from, but they are always way to high or low, and have no true meaning. I asked about them in the forum of one hardware monitoring program's web site, and they were not sure what they were. I doubt very highly that anything is wrong with your PC.
Empleados
5.580 Vistas
Responder
