16835 Discussions
Can't install linux
Nahian4663
I can't install linux on my core i5 10400.I have a gigabyte h510-M motherboard and 8gb 3200mhz ram.I tried both kali linux and parrot but Couldn't install.Every time I tried to install it shows hardware error cpu machins check 0 bank 6.Someone told me it’s the problem with 10th gen processor.Everything except linux are working just fine.No problem there.I only can't boot linux.Please intel solve this problem.
David_G_Intel
Hello Nahian4663
Thank you for posting on the Intel️® communities. Please share with us the following infromation:
  • Which BIOS version do you use?
  • Did you try booting with minimal configuration?
  • Does it work with Windows 10*?
  • If it works please share the Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
