16766 토론
Cant install drivers for my i7-4770k cpu @ 3.50ghz 3.50 ghz
Trond
초급자
7,788 조회수
I did a reinstall on my PC and as i try to install drivers for my processor i get the error:
"This system does not meet the minimum requirements to install the software"
This is odd as i had all drivers updated prior to the reinstall. It is an older PC but surely it should be possible to update drivers for my components?
Would really appreciate any feedback.
Sincerely
Trond Mjøs
0 포인트
1 솔루션
n_scott_pearson
수퍼 사용자
7,657 조회수
Hah! You probably upgraded from Windows 7 and were running old drivers and/or Windows 10-supplied replacements.
As you've seen, the only drivers you'll find still available on the Intel site are for the processor's graphics engine. After that, you need to continue in terms of the motherboard and its chipset.
Your motherboard manufacturer will provide a version of the Chipset Device Software (a.k.a. INF Update) package that will optimally configure MS-supplied drivers for the chipset and a few of the processor devices. If they do not offer a version for Windows 10, let me know; I have versions in my archive that work with my 4th gen/8 Series motherboard and which should work with your board. It's important to install this before worrying about any other devices.
What other drivers you need should, with only a few exceptions, be automatically supplied inbox with Windows 10. If there are any exceptions, it will be devices provided by the motherboard that do not have drivers in the MS catalog. These must then come from the motherboard manufacturer or the device supplier directly.
Hope this helps,
원본 게시물의 솔루션 보기
0 포인트
8 응답
AlHill
수퍼 사용자
7,770 조회수
What OS are you using?
0 포인트
Trond
초급자
7,708 조회수
Windows 10, the i7-4770K is a 4 gen processor and not supported by Windows 11 wich require an 7 gen.
Trond
0 포인트
n_scott_pearson
수퍼 사용자
7,745 조회수
...And what driver(s) are you trying to install?
0 포인트
Trond
초급자
7,707 조회수
0 포인트
n_scott_pearson
수퍼 사용자
7,658 조회수
Hope this helps,
0 포인트
Trond
초급자
7,652 조회수
Thank you for explaining this to me! Its not easy figuring out this stuff when you know jack all about PC and how it works. Ill get the motherboard drivers and work through that, hopefully that will sort it.
I guess the best long term solution is to retire my 9 year old PC, poor old thing deserves to rest. And i deserve an upgrade:-). Thank you guys for taking the time, much appreciated!
Trond
0 포인트
AlHill
수퍼 사용자
7,691 조회수
Actually, W11 requires an 8th gen or later, with few exceptions.
Ok, so you have W10.  Specifically, what drivers are you talking about?
You need to be specific.  What problem are you having?  What "drivers" do you think you need?
0 포인트
Jocelyn_Intel
직원
7,667 조회수
Hello, @Trond
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and are trying to help. You may also find the Discontinued Products website, helping to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Marketing Status > "Discontinued":  Intel® Core™ i7-4770K Processor
Jocelyn M.
0 포인트
응답
