16810 Discussions
Choosing fastest memory for i7 860 p55 NOT OVERCLOCKED
Hello everyone,
I will be using the Gigabyte GA-P55A-UD7 (Rev 1.0) P55 motherbard and an i7 860 processor. Although this is an "over clockers" mobo, I do NOT intend to over clock. I am trying to build a rock solid machine that will be running 24/7/365. As such I could use some guidance choosing the memory to provide the fastest operation while maintaining maximum stability. Is there a chart somewhere that shows ddr3 memory types and the interactions with the P55 chipset and i7 860's internal timing?
Jim
Salem_W_Intel1
We do have tested memory lists for our desktop boards; see the following URL:
http://www.intel.com/support/motherboards/desktop/sb/CS-025414.htm
I do not know if Gigabyte has something similar, but you could check with them.
As for the Intel(R) Core(TM) i7-860 Processor and what memory types it supports, and the general specifications of it, please, refer to the following URL:
http://ark.intel.com/Product.aspx?id=41316&code=Intel%C2%AE+Core%E2%84%A2+i7-860+Processor+%288M+Cache%2c+2.80+GHz%29
