17147 Discussions
Clarkdale i5 661 iGPU GMA HD BUG/Artefact on Media Center 7
Here is a bug I encounter with the Clarkdale i5 661 GPU and Media Center 7. It seems when graphic accelerated Media Center interface is used, some element is saved in memory and is kept in the right of the screen as a 1 pixel vertical line artefact that can be resolved in refreshing the UI, like reducing/reopening in full screen Media Center.
You can see the issue here : http://www.youtube.com/watch?v=k1tWseA1nk0 http://www.youtube.com/watch?v=k1tWseA1nk0
I don't have this issue with other graphic accelerated softwares like Arcsoft TotalMedia. It seems to be a bug only related with Intel iGPU HD drivers and Media Center. I don't have this with NVIDIA or ATI. I have of course all the last drivers, including intel GPU : 15.17.9.2182. All of this plugged on a Asus P7H57D-V EVO motherboard. I will post the bug to Microsoft too, but I think it's more a graphic drivers bug!
Thanks for your lights or support!
OK, I had a fix for this thanks to Sergio from the intel Chat support. Here is a hotfix published by Microsoft that will be deployed in the next Windows 7 Service Pack that resolves this issue. Thanks to use it only if you encounter this behavior in using a 1920x1080 resolution and Media Center, and don't forget to make a system backup before installing it.
http://support.microsoft.com/kb/974324/en-us?fr=1 http://support.microsoft.com/kb/974324/en-us?fr=1
