16954 Discussions
Codec engines of Intel procesors
nish_2411
I checked the product specifications page of  Intel® Core™ i5-1135G7 Processor to find the number of codec engines and found it as 2.
I want to know the same for
Intel® Core™ i5-11500 Processor
Intel® Core™ i7-11700 Processor
Intel® Xeon® E-2374G Processor
But there is no information in the respective sites regarding codec engines.
Can I get these info ?
AndrewG_Intel
Hello @nish_2411
We understand that you are looking to know the number of Multi-Format Codec Engines for the 3 processors above.
Please allow us to look into this and we will be posting back as soon as more information is available.
Andrew G.
Alberto_R_Intel
nish_2411, I just received an update on this matter.
Intel® UHD Graphics 770 (12th Gen like i5-12500) has 2 Multi-Format Codec Engines as well, which is the same as Intel® Iris® Xe Graphics (like i5-1135G7).
We did not see Intel® UHD Graphics 750 (11th Gen like i5-11500) has this Multi-Format Codec Engines listed, we believe it is different with Intel® UHD Graphics 770, which means Intel® UHD Graphics 750 doesn’t have 2 codes engines per understanding.
There is no difference between Intel® Iris® Xe Graphics and Intel® UHD Graphics 750 for decoding and encoding capability. Intel® UHD Graphics 770 doesn’t have 2 codes engines capability:
https://www.intel.com/content/www/us/en/developer/articles/technical/encode-and-decode-capabilities-for-7th-generation-intel-core-processors-and-newer.html
Encode and Decode Capabilities for 7th Generation Intel® Core™ Processors and Newer will be updated for 12th and 13th gen, but for 11th generation information showing is provided above:
Albert R.
nish_2411
Thanks so much for the reply.
One clarification.
I see a mismatch between 1st and 3rd paragraph.
Did you mean
There is no difference between Intel® Iris® Xe Graphics and Intel® UHD Graphics 770 for decoding and encoding capability. Intel® UHD Graphics 750 doesn’t have 2 codes engines capability:
Alberto_R_Intel
nish_2411, You are very welcome, thank you very much for your response.
I will confirm those details and share the updates as soon as possible.
Albert R.
Alberto_R_Intel
Hello nish_2411, I just received an update on this matter.
After confirming the information provided previously, you were right, what we meant to say was that there is no difference between Intel® Iris® Xe Graphics and Intel® UHD Graphics 770 for decoding and encoding capability. Intel® UHD Graphics 750 doesn’t have 2-codes engine capability.
Albert R.
Alberto_R_Intel
Hello nish_2411, With the previous clarification, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello nish_2411, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
