17496 Discussions
Cooling Setup Question
JMarr3
Not sure if this is the right board to post this.
I recently purchased an Intel RTS2011LC liquid cooler to pair with a 3770K processor on a DZ77GA-70K motherboard. It seems that the cooler can be set up using two fans in a push-pull fashion. As there is only one fan included and little info on the fan specs can anyone recommend as a second fan for this unit set up as described? Will it matter if the fan RPM specs are not the same as the Intel fan included with the cooler? I was going to leave my case fan in place as exhaust and install the Intel radiator on top of that and then using the Intel fan to push air into the radiator. Is this a feasible set up or will I have issues with regard to proper operation and cooling?
Thanks for your help. John
Please find below a link with the installation instructions for this cooling solution. You will also have access to instructions videos:
http://www.intel.com/support/processors/sb/CS-032999.htm http://www.intel.com/support/processors/sb/CS-032999.htm
Also, for this Processor you can use an air cooling solution. Its part number is RTS2011LC.
