17258 Discussions
Core I7-11700K High Temperature CPU
addelucas123
New Contributor II
Good evening, I have a small problem or maybe it's not a problem. Let's see the energy issue of the stock Intel Core i7-11700K processor, how much does it consume? Why did I realize that setting automatic as it comes from the factory works in demanding games? 83 degrees Celsius, And if I reduce the power of the processor to 125W Watts, if I'm not mistaken, it reaches 65 to 75 watts. Which one do you recommend without losing performance and stability of the processor? I repeat, this is automatic, but which one do you recommend? 100 watts, 125 watts, 150 watts, Which one advises me to try to lower the temperature so that I don't lose performance and also stability, I need help, If I use the Cinebench R23 program automatically, it consumes watts between 215, it can vary depending on the load I use, which advises me without losing stability and performance, because in games it gets very hot and the Intel Arc A770 graphics equally heat up both CPUs between 80 and 83 degrees and GPU 84 degrees Celsius, what do you recommend 100 watts, 115watts, 120watts, 125watts what do you recommend, for an i7-11700K processor, and I have liquid cooling
DhannielM_Intel
Hi addelucas123,
Thank you for posting on the community.
Based on your statement when Core i7-11700K processor is running at stock without reducing the power you are having 83 degrees Celsius.
1. Can you share to me if this is happening when gaming , on idle, or both? If this is happening on game what is the name of the game?
2. Also, on Cinebench are you running a stress test using this application?
While at it, can you help generate a System Support Utility (SSU) for me to fully understand your system. You can follow this link for the instructions: How to get the Intel® System Support Utility Logs on Windows*
Dhanniel M.
addelucas123
New Contributor II
Good morning, I'll be reached 83 degrees Celsius in the triple AAA game, example RDR2, Cyberpunk 2077 and other games, I did the test Cinebench, of course putting stock of factory that would be 225 or 230 watts gives me Intel Corr i7-11700k 14300 points reaches 83 degrees Celsius, And finally if I lower the energy watts to 200 watts more or less with 75 and 80 degrees Celsius but of course I lose 14300 points and what I want is to keep the same 14300 points gross performance but with less energy, I don't know if he explained
addelucas123
New Contributor II
Here you have the files, I hope you understand.
DhannielM_Intel
Hi addelucas123,
Thank you for your response. As you want to lower your temperature on your i7-11700K, how about trying this troubleshooting steps. Please refer to this link about the instruction i which you can follow: Overheating Symptoms and Troubleshooting for Intel® Boxed Processors.
Please let me what will be the outcome for this troubleshooting so we can conduct further investigation on this. I am looking forward hearing from you.
Dhanniel M.
addelucas123
New Contributor II
Good morning, still, let's leave the issue here, I'm waiting when mine is going to arrive? when mine the Intel Arc drivers arrive, I'm burned of you burned
addelucas123
New Contributor II
I'm burned EEA, I've been waiting like this for 2 or 3 years and no solution, I don't know if the developers of Intel drivers, this is going to get better or not, tell the truth if it's going to get better, don't lie to people please.
DhannielM_Intel
Hi addelucas123,
I do apologize for the delay in the update of the graphics driver. I will inform our Engineers about this. For now since the issue that we are tackling on this thread is about the Core i7-11700K high temperature. Therefore, I will be moving this discussion to our processor forum. For now please let me know if the troubleshooting that I have provided improve your core i7-11700K processor temperature? I am looking forward hearing from you.
Dhanniel M.
DhannielM_Intel
Hi addelucas123,
I hope you had the opportunity to review the information I posted. At your earliest convenience, please let me know so we can determine the best course of action to resolve this matter efficiently.
Dhanniel M.
DhannielM_Intel
Hi addelucas123,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dhanniel M.
