16902 Discussions
Core i7 14700k esquentando muito
PauloSergio
Boa noite!
Tenho uma placa mae gigabyte b760m e um processador i7 14700k, estou notando que ele esquenta muito e sei sobre o assunto do undervoltz. Como fazer nesse chipset essa configuração ?
RamyerM_Intel
Hello PauloSergio,
Por favor, esteja ciente de que só podemos apoiá-lo em inglês. Usamos uma ferramenta de tradução web para traduzir essa resposta, portanto, pode haver alguma tradução imprecisa.
Thank you for posting in the communities. I noticed you mention about overheating issues with your system. Before underclocking your system, it would be best to try and diagnose the source of the issue first. For this step, may I please know the cooling system and power supply that you are using? Additionally, what is the specific temperature that you are seeing and what software are you using to observe it? You may also share your SSU logs so I can be more familiar with your system configuration. I will be waiting for your reply.
Ramyer M.
PauloSergio
Segue o teste
JeanetteC_Intel
Hello PauloSergio
Thank you for sharing your SSU log file. It would be a great help if we could get more information about your system to properly analyze the root cause. Kindly fill in the following details below:
1) What cooling system is used?
2) What PSU make and model does your system have?
3) How much temperature is registering when you say "it's getting very hot"? What application is used for monitoring the temp?
4) Is the behavior (getting high temperature) happening only when a specific application is running? If yes, provide the application(s) that triggers the issue.
We will be waiting for your reply.
Jeanette C.
JeanetteC_Intel
Hello PauloSergio
Were you able to check the previous post? We are just waiting for the additional details we request from you, so we can identify the next steps that need to be taken to solve this issue.
JeanetteC.
RamyerM_Intel
Hello PauloSergio,
I hope you are doing well. As we have not heard a response in the past few days, we will proceed in closing your case. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Ramyer M.
PauloSergio
Nao estou conseguindo responder!
Vou enviar via imagem
