17262 Discussions
Cscript running on in band mode with Linux
DiJin
I was trying to run Cscript on Linux (Ubuntu 22.04) with in-band mode on SRF CPU, but it always returns errors as attached with command 'python3.8 startCscripts.py -a inband -p SRF'
I changed the kernal from 6 to 5, but the errors are the same, so I would like to know if it's the OS issue like not supported on Ubuntu 22.04? But I checked the manual again, it says 22.04 is supported.
Due to customer limitations, I cannot use Windows OS or host mode. Any suggestions are appreciated.
Di
JeanetteC_Intel
Hello DiJin,
We'll check on this query and we will post an update once it's available
Jeanette C.
JeanetteC_Intel
Hello DiJin,
To better understand and be able to provide appropriate resolution, please help provide the missing key information here:
1) Make and model of your system device;
2) Reason for running the Cscript.
Additionally, please help submit the Intel® System Support Utility (Intel® SSU) log file so we can further check your exact system configuration (If possible).
Intel® System Support Utility for Windows*
Intel® System Support Utility for the Linux* Operating System
We will wait for your reply.
Jeanette C.
JeanetteC_Intel
Hello DiJin,
Let us know if you have any questions
Jeanette C.
JeanetteC_Intel
Hello DiJin,
We have not received any response in the past few days. We will now proceed in closing this thread.
Sincerely,
Jeanette C.
