16766 Discusiones
D850MVSE MoBo Processor Upgrade From 1.8 to 2.8
Empleados
2.864 Vistas
Can I install and use an Intel P4 Processor rated at 2.6 or 2.8GHz 400MHz 512Kb on a D850MVSE motherboard with AA number of AA A69215-302?
The processor I am currently using is an Intel P4 rated at 1.8GHz 400MHz 256Kb.
Both prcessors are 13micron.
Would like to speed the old board up a little.
0 kudos
7 Respuestas
RGiff
Colaborador Distinguido I
1.801 Vistas
A P4 2.6 is as high as you can Go. The board does not support anything higher , I would say It's Time for a new Build . END OF LIFE according to Intel.
Empleados
1.801 Vistas
Are there any comments offered regarding the 512Kb vs the 256Kb which I am currently using. Actually the question is can I replace the 356Kb processor with one rated 512Kb with out harm?
RGiff
1.801 Vistas
If you are refering to the Cashe No Higher is better.
Empleados
1.801 Vistas
Is the cache rating a function of the processor chip or the mobo?
What would happen if I installed the 2.8? Would it just run at 2.6 or would it screw something up?
RGiff
1.801 Vistas
When Intel says a board is rated for a certin CPU , it's normaily for serval reasons , Like the Watts the CPU draws , and what the chipset level can handle . What I mean is if your board is rated for a 95 watt CPU and you install a 130 watt CPU , It either will not post or make smoke . Do you want to chance. Unless you know all the specs of Both CPUs and they the same except for the rated speed , I would stick to the rated and tested specs.
Empleados
1.801 Vistas
Bob,
I want to thank you for your time and willingness to share information. You have been a big help in helping me sort out some things I needed to deal with. Back to your original post, it is time for a rebuild and I am probably moving in that direction but in the mean time I want to keep old betsy running in the best shape I can for as long as I can.
Again, thanks.
Docster
RGiff
1.801 Vistas
Your Welcome , If you are going to do a new build my best advice is to Plain ahead and cherry pick the components carefuly , This stuff is changing so fast that if you plain to build a 775 sys the parts may not be available , If you are going to build a Icore 7 sys you realy need to pick your parts with a great deal of thought. I just finished what will be my last 775 build . That Intel Said could not be done. It's a DX48BT2 , with a XEON X3380 , and 8 gigs . Intel said it would not work , But i am using it to send you this post. So listen to the experts But make your own choices.
Responder
