17157 Discussions
DP43TF dual core support?
Had this board with windows vista installed previously,
i had to get a replacement board because of damge done during over sea's shipping.
Got the same exact model, but now it won't boot into vista unless I turn off multiplexing, so i only have one core active.
When its on, it just hangs at the screen BEFORE the windows logo, just a blinking underscore that goes on forever.
System specs as follows:
DDR2 4gb
Geforce 260 868mb
intel core 2 duo conroe 2.
sorry guess i forgot to ask the obvious,
any idea why the board wont boot into dual core? its a bit annoying to have my performance stunted becaue of it
What is the SL number of your CPU?
Intel(R) Processor Identification Utility
Version: 4.20.20090811
Time Stamp: 2009/10/14 00:01:56
Operating System: 6.0-6001-Service Pack 1
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 1
Disabled cores per processor: 1
Processor Name: Intel(R) Core(TM)2 Duo CPU E6400 @ 2.13GHz
Type: 0
Family: 6
Model: F
Stepping: 6
Revision: CB
Maximum CPUID Level: A
L1 Instruction Cache: 32 KB
L1 Data Cache: 32 KB
L2 Cache: 2 MB
Packaging: LGA775
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: No
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: No
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: Yes
Expected Processor Frequency: 2.13 GHz
Reported Processor Frequency: 2.13 GHz
Expected System Bus Frequency: 1066 MHz
Reported System Bus Frequency: 1066 MHz
That is what intels cpu identification tool reveals.
Ok, I am afraid that didn't really help too much. The reason i ask for the SL is because tehre are at least three different SL for that CPU and only two of them are compatible with the board so it would be worth checking. The other thing i would do is update the BIOS by the following the instructions in this link: http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm
I turned off extended CPUID functions in the bios and it now boots in with dual core. I don't understand why it does this since Vista should support that but, whatever, I won't question providence.
Thanks guys!
