16805 Discussions
EAX=7, ECX=0: Extended Features
CPUID
using the attached files, how can I add the CPU feature AVX2 to my binary file
I have converted Hexadecimal to Binary for my needs but I'm not sure which code represents AVX2. I think it's suppose to be EAX=7 but which is it, if anyone knows, please
Steven_Intel
Hello CPUID,
Is this related to your other post in this link? https://community.intel.com/t5/Processors/ESXi-7-0e-with-Ryzen-5950x/m-p/1390254#M58103
Steven G.
n_scott_pearson
CPUID should be invoked with EAX=0x07 and ECX=0x00. In the resulting EBX value, availability of AVX2 is indicated by Bit 05. To check it, you should AND the EBX value with 0x20; if the result is then non-zero, you know your processor has support for AVX2.
Hope this helps,
