17163 Discussions
EC5549 1366 Compatibility Question
I recently pulled one of these chips out of a server and was testing it in my Gigabyte X58A-OC. I attempted to boot the board and got the no processor installed boot code (which I expected). However, when I went to put my i7 920 back in, I noticed that three of the pins in the socket were burned and/or broken. I checked the bottom of the EC5549 and they were all stuck to that.
Is the pinout on the bottom of the EC5549 different than a 920? I didn't surprise me that it didn't boot as it's not explicitly listed as a compatible chip from Gigabyte. However, I was quite surprised that it killed my board. Under the http://ark.intel.com/products/47639/Intel-Xeon-Processor-EC5549-(8M-Cache-2_53-GHz-5_87-GTs-Intel-QPI) specifications, it lists FCLGA1366 as the supported socket which is the same as the http://ark.intel.com/products/37147/Intel-Core-i7-920-Processor-(8M-Cache-2_66-GHz-4_80-GTs-Intel-QPI) i7 920.
I've got a dead board now and I'm trying to figure out why...
Adolfo_S_Intel2
Keep in mind that the fact that 2 processors are based on the same socket (1366 in this case), it does not necessarily make them compatible with a particular motherboard, that is why all motherboard manufacturers most have a list of supported / tested processors.
And depending on the motherboard manufacturer, in some cases if you install a non-supported processor there, the motherboard might be damaged and even the processor can also be damaged, that is why we suggest testing a processor only on a motherboard that is fully compatible with the processor, and that is by checking the list of compatible processors for the specific motherboard.
