16764 Discussions
Es compatible un Intel Xeon E5-1607 3,0 GHz Quad-Core SR0L8 Sockel 2011 Prozessor con una placa base chipset x79 ddr3 socket fclga2011 R?
JHERN5
tengo una placa MSI X79A-GD45 8D socket intel 2011 R (FCLGA2011) y he comprado un procesador intel xeon e5-1607 3.o GHz, quisiera saber si este procesador que si es util para el socket de mi placa es o no compatible con el chipset x79, ya que también funciona con memoria RAM DDR3 como el i7 3820 que llevaba y se me ha estropeado.
Espero vuestras respuestas.
Gracias
AlHill
You need to ask MSI what processors are compatible with THEIR BIOS. Then, you can select from those processors.
Read the second paragraph here:
https://www.intel.com/content/www/us/en/support/articles/000005682/processors.html Intel® Desktop Processor Upgrade Information
Doc
Hi José,
Our community is only supported in English.
As Al Hill mentioned previously, it is necessary to confirm with MSI* if the Intel® Xeon® E5-1607 is supported by MSI X79A-GD45 8D.
I am sending you the list of compatible processors for the MSI X79A-GD45 8D. The E5-1607 is not shown as supported.
https://www.msi.com/Motherboard/support/X79A-GD45-8D# support-cpu
Miguel C
Intel Customer Support
Hi José,
I am following up on your post. Please let me know if I can help you with anything else.
Miguel C
