Seems to be a common experience with this game. This online guide If Black Ops 6 is freezing, stuttering, or there are sudden FPS drops on PC, here’s what you can do to fix them may help.
Hi Lordd,
Thank you for posting in the Community!
I would like to know what the Intel Graphics Card model is you're using.
- What is the graphics driver you are using?
- Confirm you are using the latest WHQL graphics driver (32.0.101.6458/32.0.101.6257) available (let us know the exact driver version you are using).
- A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
- You could also test using the latest non-WHQL driver. This driver goes through all Intel quality assurance processes and is safe to use for evaluation.
I would like to ask the following as well:
- Describe the performance issue as best as you can.
- Per example: FPS drop when entering ‘x’ or ‘y’ section.
- Provide screenshots or describe the graphics settings used in-game.
- Per example: Ultra quality preset, video resolution, ray-tracing on, etc. etc.
- Submit CapFrameX capture data (.json files) reproducing the issue.
- Capture data at least 3 times to define a good performance baseline.
About CapFrameX
This is a 3rd party tool for frametimes capture and analysis based on Intel's PresentMon. The overlay is provided by Rivatuner Statistics Server (RTSS).
CapFrameX Installation instructions:
- Go to https://www.capframex.com/download and download the latest version of CapframeX.
- Go to https://www.guru3d.com/files-details/rtss-rivatuner-statistics-server-download.html and download the latest version of RTSS.
- Unzip both installers and install them.
- Launch CapFrameX and then close it. This is so it creates the user Configuration folder.
- Download and unzip the file OverlayEntryConfiguration_0.json (attached in this post) with the recommended RTSS configuration.
- Paste this file to %userprofile%\Documents\CapFrameX\Configuration.
- In the Capture tab, set the "Capture time" to 0. This is to remove the preset limit in capture time.
- In the Overlay tab, uncheck "Auto-Disable OSD" and click the save icon.
Capturing the Performance Data:
- Open CapframeX and do NOT minimize or close it.
- Open the game and go to the part of the game you need to be to reproduce the issue. You should see the RTSS overlay in the top left corner of your screen, with the status "<game name> ready to capture…".
- Press F11 to start capturing data and reproduce the issue. The Status in the overlay will change to "Recording frametimes XX s".
- Once you have reproduced the issue, press F11 to finish the data capturing. The Status in the overlay will change to "Processing data".
- Back to CapFrameX, you can find all the data captures in the left panel of the Analysis tab. Clicking any one of these captures will display the results on the right.
- To export the data captured as a JSON file, right click the capture and click on "Copy/paste recording file(s)".
Dean R.
Hi Lordd,
Dean R.
Hi Lordd,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
