17152 Discussions
Extreme Tuning Utility - shows incorrect CPU frequency
NDunn
After running a benchmark, the XTU shows the maximum core frequency as 3.8GHz (the default clock speed of my i5 7600K) when it should read 4.4GHz, as that is what the CPU is overclocked to...does anyone know why this is and how to remedy it?
Hello IcedDog,
Could you please check in your BIOS configuration what is the base frequency? I just want to check if the XTU is pulling the information correctly from your BIOS configuration. One more thing that I would like to check is the report from the Intel® Processor Diagnostic Tool, so please run the utility and attach the report.
Intel® Processor Diagnostic Tool; https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Download Intel® Processor Diagnostic Tool.
Amy.
NDunn
Hi, the BIOS shows the correct base clock of 100MHz. I ran the IPDT and attached the full report. I see the report did note the actual CPU frequency of 4.8GHz, which is what I have it currently overclocked at...
CPU1
CPU Frequency Test
Module Version: 1.0.16.64b.W
Start Time: Tue Jan 24 20:46:37 2017
Test Result - PASS
Processor Name: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
Expected CPU Frequency: 3.80
Detected CPU Frequency: 4.80001
Expected Base Clock: 100
Detected Base Clock: 100
Thank you for that information.
For testing purposes, could you please set the frequency to the stock frequency and run the benchmark one more time?
Amy.
ssote
New Contributor II
What does CPU-Z show for clock Speed?
NDunn
CPU-Z always shows 4.8GHz under load, but I just ran the XTU benchmark again and it now shows the correct frequency of 4.8GHz in every relevant field...not sure what changed, but hey, it seems to work properly now
It might have been a misreading from the BIOS. I glad to hear that it is working.
If there is something else I can help you with, please let me know.
Amy.
Cvand1
Hey guys,
I seem to be having the same issue.
CPULoad Success
--- CPU Frequency Test ---
Version 1.0.16.64b.W
Expected CPU Frequency is -- 4.20
Detected CPU Frequency is -- 4.80001
Expected Base Clock -- 100 MHz
Detected Base Clock -- 100 MHz
CPU Frequency Test Passed
NoseyTable,
Thank you for joining the thread.
For us to further assist you and to help you with the specific problem, please create a new thread, make sure to add all the details in regard to your system. This way the next agent will have a better look at your specific scenario, you can add this thread as a reference but I recommend creating a new thread in order to isolate your case.
Amy C.
