17160 Discussions
FCBGA1787 Ball Map i5-11400H
VladyslavProtsak
Hello, can I get a document containing the socket FCBGA1787 ball map in order to make a stencil (needed to repair a laptop board) or is this confidential information?
Mike_Intel
Hello VladyslavProtsak,
  1. What us the brand and model of your laptop?
  2. What is the issue that you encounter?
  3. What kind of repair are you trying to do?
Michael L.
VladyslavProtsak
Asus FX506HM laptop, Quannta NJH motherboard. When soldering a faulty processor (due to liquid getting under it), the board mask was damaged. There is a method for restoring the mask with ultraviolet varnish, but for this you need to make a stencil on a transparent film. On the Internet, I found only raster images of the socket without specifying the size of the stencil and the gap between the balls, maybe you can provide a vector image or an image with the specified dimensions.
Mike_Intel
Thank you for the update.
Just to check, have you tried contacting Asus about this since the system that you are working on is an Asus unit?
If yes, you can you tell me what is their reply?
Michael L.
Mike_Intel
Michael L.
VladyslavProtsak
Asus suggests that I contact an authorized service center. Unfortunately, they do not work in my country. Perhaps I did not explain correctly what I need, due to poor knowledge of English. I am attaching a screenshot from the datasheet of another chip, it contains what I need, I thought that Intel could also provide this information or a datasheet for a similar processor.
Mike_Intel
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Thank you for patiently waiting for my update.
Upon checking, the mechanical drawings of Intel processors are not released publicly.
However you can locate for the files that you need here: Intel's Resource & Documentation Center
Michael L.
