17148 Discussions
Few days ago, i cleaned up my PC. i removed cooler and didn't applied new thermal paste. after it all the games was lagging and fps was too low, i trough it was GPU fault, made few tests and nothing came up. so i made a CPU test, i have intel i-7. test sa
ZZuka
Hello, Few days ago, i cleaned up my PC. i removed cooler and didn't applied new thermal paste. after it all the games was lagging and fps was too low, i trough it was GPU fault, made few tests and nothing came up. so i made a CPU test, i have intel i-7. test said that problem is in thermal solution. today i applied thermal paste and problem begin solved, no more low FPS on games no lagging. but test result is same, always failing at temperature.
Sorry for my English.
checkExpected Greater than 1 degrees below max Received 3 degrees below max Test PASSED 2 degrees C below maximum Test Result - PASS Expected Greater than 1 degrees below max Received 2 degrees below max Test PASSED 3 degrees C below maximum Test Result - PASS Expected Greater than 1 degrees below max Received 3 degrees below max Test PASSED 1 degrees C below maximum Test Result - FAIL Expected Greater than 1 degrees below max Received 1 degrees below max Test FAILED Please check your Processor Thermal Solution Temperature Monitor Stopped -------------------------------------------------------------------- System Information ------------------ Processor Name: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz Processor Information: Intel64 Family 6 Model 60 Stepping 3 Number of Physical Cores: 4 Number of Logical Cores: 8 Installed System Memory: 16 GB Operating System: Microsoft Windows 10 Pro 64-bit Graphics Information: NVIDIA GeForce GTX 770 System Product: Z87-K System BIOS: 0801 System Serial Number: System Serial Number -------------------------------------------------------------------- --- IPDT64 - End Time: 10/11/2016 2:18:11 PM --- IPDT64 - Result: Fail --------------------------------------------------------------------
ZZuka
uppppppppp
CCris2
New Contributor II
Hi Zurab ,
I advise you to check if cooler is mounted correctly on the CPU, and to do a bios update from this page and read all the notes from each bios version because there is tool that they recommend to use.
Are you using a custom cooler or the Intel default ?
Allan_J_Intel1
It will be a good practice to add new thermal material after reseating the fan and heatsink.
You can request new thermal material by contacting the processor support team at http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
Allan.
