16964 Discussions
Fragging in windows 10 while playing fifa 17
CAlex2
So, i have a little problem: when i play fifa 17 full screen and after few minutes of playing, i tap "ALT"&"TAB" and in desktop i'm fragging while i move the mouse, and after i close fifa it's all just fine. If i play fifa 17 Windowed it's all ok, no fraggs. I tested in Cs:go and there is no problem at all.
While gaming cpu and ram utilisation ( task manager always on top):
fifa 17 window - up to 60% cpu , and 5.1 gb ram ( out of 8)
fifa 17 full screen - can't open fifa ( acctually i opend fifa but i just hear, i cant see, * same problem like if TeamViewer cant play in full screen if logged in
cs:go full screen - up yo 97% cpu ( i dont think thats ok) , and 4.5-5.0 gb ram ( out of 8)
PC specs:
cpu :i7 6700k 4.00ghz ( boost at 4.2 ) 1.30v
gpu :gtx 960 4gb ram
motherboard : asus z170 a
RAM : hyperX 8gb 2400mhZ 1.35v ( xmp profile)
SSD : Samsung Evo 750 500gb
HDD : WD green caviar 1TB 5400rpm
PSU : SuperFlower 550w
Cpu cooler : Noctua nhd14
OS : windows 10 pro 64 bit
I mention that the gpu is't mine ! I borrowed from someone and i will buy a new one.
It's any chance to be a bottleneck?
Thanks in advance.
Hello CristiAlexandru99:
Yes, this could be related to a bottleneck, in this case sine you are using a video card the Intel graphics are disable, so in order to install the latest graphics drivers we just need to visits the manufacturer's web site:
http://www.geforce.com/drivers http://www.geforce.com/drivers
Also, a BIOS update is also a good thing to try to the latest version:
https://www.asus.com/us/Motherboards/Z170-A/HelpDesk_Download/ https://www.asus.com/us/Motherboards/Z170-A/HelpDesk_Download/
Also, as a troubleshoot step, if you are going to purchase a new video card to test it with the board, that will be a good way to rule out a possible problem with the video card itself, or also before you buy it, if there is a PC repair store close to you, they might be able to test the board with a different video card.
Any further questions, please let me know.
Alberto
I just wanted to check if the information posted previously was useful for you, and if you need further assistance on this matter?
Alberto
