16970 Discussions
HOW DOES THE i7-7Y75 PROCESSOR 'S Max Turbo Frequency WORK?
nyang27
Processor Base Frequency
1.30 GHz
Max Turbo Frequency
3.60 GHz
these information was show on the Technical Specifications,i just want to know when one core work on max turbo 3.6 .does the rest core still​ work on 1.30?
I did not find burst frequency in these link.only show the 1core Max Turbo Frequency.
Datasheet, Vol. 1: 7th Gen Intel® Core™ Processor U/Y-Platforms:
http://www.intel.com/content/www/us/en/processors/core/7th-gen-core-family-mobile-u-y-processor-lines-datasheet-vol-1.html
Datasheet, Vol. 2: 7th Gen Intel® Core™ Processor U/Y-Platforms:
http://www.intel.com/content/www/us/en/processors/core/7th-gen-core-family-mobile-u-y-processor-lines-datasheet-vol-2.html
7th Gen Intel® Core™ Processor Families Specification Update:
http://www.intel.com/content/www/us/en/processors/core/7th-gen-core-family-spec-update.html
Datasheet, Vol. 1: 7th Gen Intel® Core™ Processor I/O for U/Y Platform:
http://www.intel.com/content/www/us/en/processors/core/7th-gen-core-family-mobile-u-y-processor-lines-i-o-datasheet-vol-1.html
Datasheet, Vol. 2: 7th Gen Intel® Core™ Processor I/O for U/Y Platform:
http://www.intel.com/content/www/us/en/processors/core/7th-gen-core-family-mobile-u-y-processor-lines-i-o-datasheet-vol-2.html
7th Gen Intel® Processor I/O for U/Y Platforms Specification Update:
http://www.intel.com/content/www/us/en/processors/core/7th-gen-core-family-mobile-u-y-processor-lines-i-o-spec-update.html
And i still can not check I7 7700K BFM
how about 7700k double core?3core?4core works on the Max Turbo Frequency?
Hope to show me the date or give the link to me.
Wanner_G_Intel
Hello nyang27,
Thank you for submitting your question on this Intel® Community.
Intel® Turbo Boost Technology is a processor technology and can't be enabled or disabled by core. If one core is active, the technology is enabled.
For Intel® Core™ i7-7Y75 Processor, the maximum single core frequency at which the processor is capable of operating using Intel® Turbo Boost Technology is 3.60 GHz.
With multi-cores, however, the frequencies the cores will be working at depends on the number of active cores, workload, temperature, system configuration, and other conditions that allow the processor to enter turbo mode. Also, with multi-cores, the possible achievable Turbo Boost Frequency is up to 3.60 GHz.
It is worth noting that in some cases, the Max Turbo frequency may not be achieved even under 100% load.
Note: We don't disclose per core Intel® Turbo Boost Technology frequencies for processors.
If you have any further questions about this information, please let us know.
  • Now, could you please let us know what "BFM"? What is the information you are looking for?
  • "how about 7700k double core?3core?4core works on the Max Turbo Frequency?": Are you referring to Intel® Turbo Boost with multi-cores?
Wanner G.
A Contingent Worker at Intel
nyang27
Thanks you Wanner G..
could you show me the data for i7 7Y75 & i7 7700K​ ,like the reference photo? i can not find it in intel website
Wanner_G_Intel
Hello nyang27,
The information you are referring to is available at ark.intel.com under the Performance section.
Depending on the processor family, the technology that automatically runs the processor core faster than the marked frequency is called Max Turbo Frequency or Burst frequency.
For more information on Intel® Turbo Boost Technology, please refer to these links below and the datasheet of the processor.
Wanner G.
Wanner_G_Intel
Hello nyang27,
Were you able to review the information provided?
Wanner G.
nyang27
Hello WannerG
I got it .thinks,all I want is per core frequencies .
After I saw the Note: We don't disclose per core Intel® Turbo Boost Technology frequencies for processors.
Maybe i can check the further information on other forum.
Best thanks.​
