Heating problems
hmelnitskiy4589
Good day! I have an Asus X571GT Core i7 laptop and I noticed that it started to get very hot. I searched the Internet for information that could help me, but that didn't help me much. Then I tried to launch the Intel® Processor Diagnostic Tool. Tested on the site - result 60 s.
Can you tell me what the problem is?
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
hmelnitskiy4589
Thank
I thought, I'd better go to the service center.
n_scott_pearson
I can see no problem here. Getting into 60s is nothing. In fact, getting into the 70s and 80s is not an issue either; it's perfectly normal. Seeing spikes into the 90s is ok too. I draw the line there though; unless I am running the heaviest load possible, I shouldn't see sustained temperatures in the 90s. Intel Customer Support will tell you that any temperature up to the processor's Tjmax (Maximum Junction Temperature, ~100c) is ok, but that's baloney. If you are seeing temperatures in the 90s, you are going to be above the processor's thermal load line for sure - and this, if sustained, can be harmful to the processor's lifetime.
So, you're in the 60s. Happy now?
