16761 Discussions
Hello, I would like to know if core i3 2120 supports 64bit windows?
Hello, my problem is that I have a Core i3 2120, with 32bit windows, and I would like to know if I can install 64bit windows. Thanks.
AlHill
Yes, it supports 64-bit windows.
http://ark.intel.com/products/53426/Intel-Core-i3-2120-Processor-3M-Cache-3_30-GHz Intel® Core™ i3-2120 Processor (3M Cache, 3.30 GHz) Specifications
No, it is not supported on Windows 10 (but that does not mean you cannot run windows 10).
http://www.intel.com/content/www/us/en/support/processors/000006105.html Intel® Processor Support for Microsoft Windows® 10
No, the graphics are not supported on Windows 10 (but you can use the Microsoft generic driver).
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
Doc
Hello, thanks for your answer, but I'm a little confused, does that means that it supports 64bit windows (7, 8.1) but not 64bit windows 10?
AlHill
You can run 64-bit Vista, 7, 8.x, and 10. It is just that Windows 10 is not supported.
Read the links I provided.
Doc
Hello:
Thank you very much to Al Hill for the comments posted previously.
To Cyrash:
I just wanted to confirm the above information as correct, you can use Windows® 64-bit Vista, 7, 8.x, and 10 with that processor, is just that for Windows® 10 the graphics drivers are not available, but you can always use the generic drivers that get installed when you install Windows.
Alberto
